10
In shortcuts i have Super + L for locking screen. But on pressing it - nothing happens. In syslog:
gsd-media-keys[1979]: Couldn't lock screen: Cannot invoke method;
proxy is for the well-known name org.gnome.ScreenSaver without an owner, and proxy was constructed with the G_DBUS_PROXY_FLAGS_DO_NOT_AUTO_START flag
Locking from interface works fine.
System info: Ubuntu 19.04 upgraded to 20.04
Linux laptop 5.4.0-21-generic #25-Ubuntu SMP Sat Mar 28 13:10:28 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 20.04 LTS
Release:    20.04
Codename:   focal
GNOME Shell 3.36.1
Other info:
gsettings get org.gnome.desktop.screensaver lock-enabled = true
gsettings get org.gnome.desktop.lockdown disable-lock-screen = false
gnome-screensaver 3.6.1
I also tried: gnome-screensaver-command -l but nothing happens.
I already tried to reinstall gnome-shell and gnome-screensaver - it didn't help.
How to fix locking screen from hotkey?
My original question was banned as bug, but it isn't a bug - it's a wrong configuration. People faced this problem a lot in the internet and SO:
In my case I was using lightdm and screen lock is disabled in it due security issues. Read more here
You can check you display manager with: sudo systemctl status display-manager
If you still want to lock your screen with lightdm - you can use dm-tool lock. Also you can add it to keyboard shortcut as command (e.g. Super+L).
Switching to gdm3 helped: sudo dpkg-reconfigure gdm3
I face same problem after I switched my display-manager to lightdm. (because I prefer the design of lightdm over gdm)
However, I still want to lock the screen with keyboard shortcut.
So this is what I did:
Settings > Keyboard Shortcuts > '+'
Command : dm-tool lock
Shortcut : Super+L (I edited original Lock Screen shortcut to other combination)
In my case, Super+L enables the lock of the screen perfectly with this setting. Enjoy :)
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
HJ Han
  • 51
I had the same problem and none of the above worked. Had to use dconf-editor and navigate to /org/gnome/desktop/lockdown and unset 'disable-lock-screen'.
Hope this helps someone else.
sQuir3l
  • 131
