1) I've been using Ubuntu 18.04 with Windows 10 dual boot for some months now. Today suddenly my sound stopped working on Ubunutu. Activities -> Sound menu shows only "Dummy Output". All fine on Windows though.
2) Output of lsmod is:
rohit@rohitUb18043LTS:~$ lsmod | grep snd_
snd_seq_midi           20480  0
snd_seq_midi_event     16384  1 snd_seq_midi
snd_seq                69632  2 snd_seq_midi,snd_seq_midi_event
snd_rawmidi            36864  1 snd_seq_midi
snd_seq_device         16384  3 snd_seq,snd_seq_midi,snd_rawmidi
snd_soc_dmic           16384  0
snd_hda_codec_realtek   118784  0
snd_hda_codec_generic    81920  1 snd_hda_codec_realtek
ledtrig_audio          16384  2 snd_hda_codec_generic,snd_hda_codec_realtek
snd_soc_hdac_hdmi      32768  0
snd_sof_intel_hda_common    73728  1 sof_pci_dev
snd_soc_hdac_hda       24576  1 snd_sof_intel_hda_common
snd_sof_intel_hda      20480  1 snd_sof_intel_hda_common
snd_sof_intel_byt      24576  1 sof_pci_dev
snd_sof_intel_ipc      20480  1 snd_sof_intel_byt
snd_sof                98304  4 snd_sof_intel_hda_common,snd_sof_intel_byt,snd_sof_intel_ipc,sof_pci_dev
snd_sof_xtensa_dsp     16384  1 sof_pci_dev
snd_hda_ext_core       28672  4 snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_intel_hda
snd_soc_acpi_intel_match    32768  2 snd_sof_intel_hda_common,sof_pci_dev
snd_soc_acpi           16384  2 snd_soc_acpi_intel_match,sof_pci_dev
snd_soc_core          237568  5 snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_soc_dmic
snd_compress           24576  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_hda_codec_hdmi     57344  1
snd_hda_intel          53248  2
snd_intel_nhlt         20480  1 snd_hda_intel
snd_hda_codec         131072  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda
snd_hda_core           90112  10 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_intel_hda
snd_hwdep              20480  1 snd_hda_codec
snd_pcm               102400  10 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_core,snd_hda_core,snd_pcm_dmaengine
snd_timer              36864  2 snd_seq,snd_pcm
snd                    86016  17 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm,snd_rawmidi
3) I installed all updates from Software updater but no luck.
4) No change by using: sudo alsa force-reload
5) Looking around, found this thread: Sound card shown as Dummy Output in Ubuntu 18.04 . User says found the "active profile was off" and links to a solution on this forum (https://forums.linuxmint.com/viewtopic.php?t=268499). I am pasting the output of the four commands as per that link:
rohit@rohitUb18043LTS:~$ sudo fuser -v /dev/snd/*
[sudo] password for rohit:
                     USER        PID ACCESS COMMAND
/dev/snd/controlC0:  gdm        1505 F.... pulseaudio
                     rohit      1878 F.... pulseaudio
rohit@rohitUb18043LTS:~$ pacmd list-cards
1 card(s) available.
    index: 0
    driver: <module-alsa-card.c>
    owner module: 7
    properties:
        alsa.card = "0"
        alsa.card_name = "HDA NVidia"
        alsa.long_card_name = "HDA NVidia at 0xb4000000 irq 17"
        alsa.driver_name = "snd_hda_intel"
        device.bus_path = "pci-0000:01:00.1"
        sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0"
        device.bus = "pci"
        device.vendor.id = "10de"
        device.vendor.name = "NVIDIA Corporation"
        device.product.id = "0fb9"
        device.product.name = "GP107GL High Definition Audio Controller"
        device.string = "0"
        device.description = "GP107GL High Definition Audio Controller"
        module-udev-detect.discovered = "1"
        device.icon_name = "audio-card-pci"
    profiles:
        output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5400, available: no)
        output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 300, available: no)
        output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 300, available: no)
        off: Off (priority 0, available: unknown)
    active profile: <off>
    ports:
        hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
            properties:
                device.icon_name = "video-display"
rohit@rohitUb18043LTS:~$ pacmd list-sinks
1 sink(s) available.
  * index: 0
    driver: <module-null-sink.c>
    flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
    state: SUSPENDED
    suspend cause: IDLE
    priority: 1000
    volume: front-left: 65536 / 100% / 0,00 dB,   front-right: 65536 / 100% / 0,00 dB
            balance 0,00
    base volume: 65536 / 100% / 0,00 dB
    volume steps: 65537
    muted: no
    current latency: 0,00 ms
    max request: 344 KiB
    max rewind: 344 KiB
    monitor source: 0
    sample spec: s16le 2ch 44100Hz
    channel map: front-left,front-right
                 Stereo
    used by: 0
    linked by: 0
    configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
    module: 15
    properties:
        device.description = "Dummy Output"
        device.class = "abstract"
        device.icon_name = "audio-card"
rohit@rohitUb18043LTS:~$ pacmd list-sink-inputs
0 sink input(s) available.
6) I tried the suggested command but it says "No such profile".
rohit@rohitUb18043LTS:~$ pacmd set-card-profile alsa_card.pci-0000_01_00.1 output:analog-stereo+input:analog-stereo
No such profile: output:analog-stereo+input:analog-stereo
Please help - how do I proceed?
rbewoor
  • 101
