I upgraded Ubuntu to 20.04 and the setting for preferred WiFi frequency has disappeared. You can see a screenshot of the drop-down menu here:
How can I get this drop down menu back?
The dropdown menu was removed from the UI (I could not find the reason).
But there is a work-around, by checking the manual of nm-settings:
/etc/NetworkManager/system-connections/nameofconnection.nmconnectionsudo nano /etc/NetworkManager/system-connections/nameofconnection.nmconnection[wifi] add following entry
band=bgband=aCredits for @heynnema
To access the settings in a GUI execute nm-connection-editor in a terminal.
Then choose your desired connection and click on edit.
Thanks. This did the trick for me!
