The wifi signal is so weak in my laptop with ubuntu boot but works just fine with windows boot: I have tried all the possible ideas and seen a lots of forums but the wifi is still slow. I only get speed of 1 to 3 mbps with ubuntu boot but with windows boot i get roughly 30 mbps of speed. In one forum i have found of backports for a qualcomm modem but every time i try to compile it i get errors.
If anyone can help me with the backports it would be great:
My current kernel is:5.8.0-41-generic
When i run "lspci -nnk | grep -A2 0280" this command i get:
03:00.0 Network controller [0280]: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [168c:0042] (rev 31)
Subsystem: Lite-On Communications Inc Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [11ad:08a6]
Kernel driver in use: ath10k_pci
When i run 'make defconfig-ath10k' i get errors like:
Generating local configuration database from kernel ...mkdir: cannot create directory ‘.tmp_5553’: Permission denied
mkdir: cannot create directory ‘.tmp_5555’: Permission denied
mkdir: cannot create directory ‘.tmp_5557’: Permission denied
mkdir: cannot create directory ‘.tmp_5559’: Permission denied
mkdir: cannot create directory ‘.tmp_5561’: Permission denied
mkdir: cannot create directory ‘.tmp_5563’: Permission denied
mkdir: cannot create directory ‘.tmp_5566’: Permission denied
mkdir: cannot create directory ‘.tmp_5568’: Permission denied
mkdir: cannot create directory ‘.tmp_5570’: Permission denied
mkdir: cannot create directory ‘.tmp_5572’: Permission denied
mkdir: cannot create directory ‘.tmp_5574’: Permission denied
mkdir: cannot create directory ‘.tmp_5576’: Permission denied
mkdir: cannot create directory ‘.tmp_5578’: Permission denied
mkdir: cannot create directory ‘.tmp_5580’: Permission denied
mkdir: cannot create directory ‘.tmp_5582’: Permission denied
mkdir: cannot create directory ‘.tmp_5584’: Permission denied
mkdir: cannot create directory ‘.tmp_5586’: Permission denied
mkdir: cannot create directory ‘.tmp_5588’: Permission denied
mkdir: cannot create directory ‘.tmp_5590’: Permission denied
mkdir: cannot create directory ‘.tmp_5592’: Permission denied
mkdir: cannot create directory ‘.tmp_5594’: Permission denied
mkdir: cannot create directory ‘.tmp_5596’: Permission denied
mkdir: cannot create directory ‘.tmp_5598’: Permission denied
mkdir: cannot create directory ‘.tmp_5600’: Permission denied
mkdir: cannot create directory ‘.tmp_5602’: Permission denied
mkdir: cannot create directory ‘.tmp_5604’: Permission denied
mkdir: cannot create directory ‘.tmp_5606’: Permission denied
mkdir: cannot create directory ‘.tmp_5608’: Permission denied
mkdir: cannot create directory ‘.tmp_5610’: Permission denied
mkdir: cannot create directory ‘.tmp_5612’: Permission denied
mkdir: cannot create directory ‘.tmp_5615’: Permission denied
mkdir: cannot create directory ‘.tmp_5617’: Permission denied
mkdir: cannot create directory ‘.tmp_5619’: Permission denied
mkdir: cannot create directory ‘.tmp_5621’: Permission denied
mkdir: cannot create directory ‘.tmp_5623’: Permission denied
mkdir: cannot create directory ‘.tmp_5625’: Permission denied
mkdir: cannot create directory ‘.tmp_5627’: Permission denied
mkdir: cannot create directory ‘.tmp_5629’: Permission denied
mkdir: cannot create directory ‘.tmp_5631’: Permission denied
mkdir: cannot create directory ‘.tmp_5633’: Permission denied
mkdir: cannot create directory ‘.tmp_5635’: Permission denied
mkdir: cannot create directory ‘.tmp_5637’: Permission denied
mkdir: cannot create directory ‘.tmp_5639’: Permission denied
mkdir: cannot create directory ‘.tmp_5641’: Permission denied
mkdir: cannot create directory ‘.tmp_5643’: Permission denied
mkdir: cannot create directory ‘.tmp_5645’: Permission denied
done.
cc -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -c -o conf.o conf.c
lex -ozconf.lex.c -L zconf.l
yacc -ozconf.tab.c -t -l zconf.y
yacc: e - line 97 of "zconf.y", syntax error
%destructor {
make[2]: *** [Makefile:20: zconf.tab.c] Error 1
make[1]: *** [Makefile.real:41: defconfig-ath10k] Error 2
make: *** [Makefile:43: defconfig-ath10k] Error 2
When i run this command with sudo also i get errors similar like this.
If someone can help me with this would be a very great help. I am about to go mad with this slow wifi..
