I have updated to kernel 4.17.0-041700-genericand installed the Bluetooth driver going through How to activate bluetooth device for RTL8723DE?. In earlier kernel driver it was doing well.
Edit : Now I have installed 5.6.0-050600-generic and bluetooth is working but wi-fi has gone
sudo dkms install rtlwifi-new/0.6
Kernel preparation unnecessary for this kernel. Skipping...
Building module: cleaning build area......(bad exit status: 2) make -j2 KERNELRELEASE=5.3.0-46-generic -C /lib/modules/5.3.0-46-generic/build M=/var/lib/dkms/rtlwifi-new/0.6/build.........................................(bad exit status: 2) ERROR (dkms apport): binary package for rtlwifi-new: 0.6 not found Error! Bad return status for module build on kernel: 5.3.0-46-generic (x86_64) Consult /var/lib/dkms/rtlwifi-new/0.6/build/make.log for more information.
Mudit Kapil
  • 2,081
If you read the answer carefully, you could have noticed that supported kernels are 4.4-4.15.
You installed for an unknown reason the 4.17 mainline kernel. That's why the module is not building or working.
At present the RTL8723DE bluetooth device is suppored by the 5.3 kernel out of the box. This kernel is preinstalled with Ubuntu 18.04 iso and installable on the initial 18.04 release by
sudo apt install linux-generic-hwe-18.04
Pilot6
  • 92,041
