Wi-Fi works but Bluetooth doesn’t on Ubuntu 22.04, 5.15.0-40-generic.
lshw
$ sudo lshw -class network -short
H/W path Device Class Description
/0/100/1d/0 eno1 network RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
/0/100/1d.1/0 wlo1 network RTL8723DE 802.11b/g/n PCIe Adapter
dmesg
$ sudo dmesg | grep Bluetooth
returns no output.
lsmod
$ sudo lsmod | grep bt
returns no output.
bluetooth service status
$ sudo systemctl status bluetooth
○ bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
Jun 27 14:28:16 beast systemd[1]: Condition check resulted in Bluetooth service being skipped.
Jun 27 14:28:41 beast systemd[1]: Condition check resulted in Bluetooth service being skipped.
Jun 27 14:29:09 beast systemd[1]: Condition check resulted in Bluetooth service being skipped.
Jun 27 14:38:14 beast systemd[1]: Condition check resulted in Bluetooth service being skipped.
Jun 27 14:41:51 beast systemd[1]: Condition check resulted in Bluetooth service being skipped.
Jun 27 14:46:53 beast systemd[1]: Condition check resulted in Bluetooth service being skipped.
I’ve tried toggling Secure and Legacy Boot in BIOS but no results. My BIOS is up-to-date.
Contents of /lib/firmware/{rtlwifi,rtl_bt,rtw88,rtw89}
$ ls /lib/firmware/{rtlwifi,rtl_bt,rtw88,rtw89} | grep 8723
rtl8723a_fw.bin
rtl8723b_fw.bin
rtl8723bs_config-OBDA0623.bin
rtl8723bs_config-OBDA8723.bin
rtl8723bs_fw.bin
rtl8723d_config.bin
rtl8723d_fw.bin
rtl8723aufw_A.bin
rtl8723aufw_B.bin
rtl8723aufw_B_NoBT.bin
rtl8723befw_36.bin
rtl8723befw.bin
rtl8723bs_ap_wowlan.bin
rtl8723bs_bt.bin
rtl8723bs_nic.bin
rtl8723bs_wowlan.bin
rtl8723bu_ap_wowlan.bin
rtl8723bu_nic.bin
rtl8723bu_wowlan.bin
rtl8723defw.bin
rtl8723fw_B.bin
rtl8723fw.bin
rtw8723d_fw.bin
I don’t use dual-boot.
Bluetooth hardware is fine and used to work with Windows 10.
I have BlueZ and Bluetooth packages installed.
Using modeprobe btusb adds the module, allowing to start the service. But bluetoothctl devices returns no output.
Edit:
$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 05c8:03d2 Cheng Uei Precision Industry Co., Ltd (Foxlink) HP TrueVision HD Camera
dmesg retuns no output as mentioned earlier. But after modprobe btusb, returns
$ sudo dmesg | grep -i blue
[ 2449.651756] Bluetooth: Core ver 2.22
[ 2449.651796] NET: Registered PF_BLUETOOTH protocol family
[ 2449.651797] Bluetooth: HCI device and connection manager initialized
[ 2449.651802] Bluetooth: HCI socket layer initialized
[ 2449.651804] Bluetooth: L2CAP socket layer initialized
[ 2449.651808] Bluetooth: SCO socket layer initialized
[ 2475.797043] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2475.797046] Bluetooth: BNEP filters: protocol multicast
[ 2475.797049] Bluetooth: BNEP socket layer initialized
