17
I have just upgraded to a recent version of Ubuntu that uses snap apps, and I have trouble understanding how I'm supposed to use them to work with files outside of /home. I have three disks in my machine, a large photo library on sdb, backup drives, and other things. As snap apps are confined, they cannot access any of them.
Only solution I can think of, is to bind mount everything to some folder under /home, but that seems like a terrible thing to do every single time I want to look at a file. Searching the web brings up blog posts about "snap interfaces" and "snap connections", but it is unclear to me if that could be helpful.
So the question is: What is the intended method for using snap apps to work with files stored outside of /home?
kurja
  • 681
what is the intended method for using snap apps to work with files stored outside of /home?
The snap should be designed to do that under confinement by making use of the removable-media interface. Connecting such an interface will grant confined access to drives mounted in /media as well as /mnt.
To see if the snap in question supports this, run snap connections <snap name>. For example, for Nextcloud:
$ snap connections nextcloud
Interface        Plug                       Slot           Notes
network          nextcloud:network          :network       -
network-bind     nextcloud:network-bind     :network-bind  -
removable-media  nextcloud:removable-media  -              -
Since nextcloud:removable-media has no associated slot, that means the interface is not connect, thus Nextcloud cannot access removable media. To connect it, we can run sudo snap connect nextcloud:removable-media. Then the connections look like the following:
removable-media  nextcloud:removable-media  :removable-media  manual
Now that the plug is connected to a slot, Nextcloud now has confined access to removable media in /media/ and /mnt. Other applications will work the same way if the developer built such functionality in. If they didn't, log a bug! You can find where to log a bug with snap info <snap name>, for example:
$ snap info nextcloud
<snip>
contact:   https://github.com/nextcloud/nextcloud-snap
<snip>
kyrofa
  • 7,502
