During installation of Ubuntu 18.04 I created a separate partition /store. Files are accessible, but I cannot open files on it with okular and GIMP. No exact errors are displayed, okular just says Could not open file:///store/1.pdf. GIMP says: Opening '/store/2.jpg' failed:Could not open '/store/2.jpg' for reading: No such file or directory
However other programs, such as chrome, document viewer, kolourpaint read pdf, jpg files perfectly.
When inside okular/GIMP I click file->open, /store is not displayed among other folders. Neither symbolic link to it, residing in ~/Desktop is displayed.
What can be the solution?
Apogentus
  • 273
It turned out to be the limitation of installing programs with snap: it makes only files from home folder accessible. So the solution is to remove okular and gimp from snap and install using apt:
# okular
sudo snap remove okular
sudo apt install okular
# gimp
sudo snap remove gimp
sudo add-apt-repository ppa:otto-kesselgulasch/gimp
sudo apt-get update
sudo apt-get install gimp # without 2 previous lines gimp 2.8 will be installed
Apogentus
  • 273
Removing the snap and reverting to the regular APT version, if available, indeed works around the permission limits of a Snap.
In case you do not have that alternative or prefer the snap version, you may want to check the permissions in Software. Opening the permission "Read/write files on removable storage" will grant the snap application access to media mounted under /media or /mnt. The snap package has to provide that interface for this to work. See this Ask Ubuntu question and the snap documentation.
vanadium
  • 97,564
