48
When 'Update Manager' starts running, it tells me that I need to do a 'Partial Upgrade', when I start doing the upgrade, it tells me
Remove package in bad state
The package 'linux-headers-3.0.0-19' is in an inconsistent state
and needs to be reinstalled, but no archive can be found for it.
Do you want to remove this package now to continue?"
When I click 'Yes' the program just closes. I have tried to go into the software center and reinstall the linux-headers-3.0.0-19 ubuntu software center just freezes.
Right now I cannot run 'Synaptic', or remove any software.
muru
  • 207,228
Try this, I hope it works:
  1. Make a backup of /var/lib/dpkg/status:
    sudo cp /var/lib/dpkg/status /var/lib/dpkg/status.bkup
  2. Open /var/lib/dpkg/status:
    sudo nano /var/lib/dpkg/status
  3. Search through the file for any reference to that package name (i.e. linux-headers-3.0.0-19) and CAREFULLY delete that entry. Don't delete anything else. Save the file and quit.
  4. Do sudo apt-get update.
This should probably solve the problem.
Videonauth
  • 33,815
43
  • If you get nowhere with any of the other offerings I've used this in the past
    dpkg --remove --force-remove-reinstreq
    From the dpkg manual
    remove-reinstreq: Remove a package, even if it's broken
  • So run:
    sudo dpkg --remove --force-remove-reinstreq  linux-headers-3.0.0-19
user.dz
  • 49,176
