I am using Ubuntu 15.04 8u45-linux-x64.rpm and converting it to .deb using alien, then I am installing it using gdebi package installer.
now when I run a apt-get command I get this error
E: The package jre1.8.0-45 needs to be reinstalled
but I can't find an archive for it.
anyone help me?
Thanks
SamFlynn
  • 1,025
First, fix the apt-get error you're getting. Open a terminal (press Ctrl+Alt+T) and run:
sudo dpkg --remove --force-remove-reinstreq jre1.8.0-45
Once that's fixed, you should instead install it using WebUpd8's Oracle Java packages, which also automatically give you future updates when you do apt-get update.
To do so, open a terminal and run:
sudo -i
add-apt-repository ppa:webupd8team/java
apt-get update
apt-get install -y oracle-java8-installer
Olathe
  • 4,310
  • 19
  • 24
