I am trying to install xpad, Wine and get same error.
sudo apt-get install xpad
Error:
Reading package lists... Done
Building dependency tree
E: The package jdk1.8.0-101 needs to be reinstalled, but I can't find an archive for it.
How to fix it, thanks.
[UPDATE] I try to remove jdk1.8.0_101
sudo dpkg --remove --force-remove-reinstreq  jdk1.8.0-101
dpkg: warning: overriding problem because --force enabled:
dpkg: warning: package is in a very bad inconsistent state; you should
 reinstall it before attempting a removal
(Reading database ... 221715 files and directories currently installed.)
Removing jdk1.8.0-101 (1.8.0101-1) ...
find: ‘/usr/java/*’: No such file or directory
/var/lib/dpkg/info/jdk1.8.0-101.postrm: line 586: /usr/sbin/alternatives: No such file or directory
/var/lib/dpkg/info/jdk1.8.0-101.postrm: line 598: /usr/sbin/alternatives: No such file or directory
dpkg: error processing package jdk1.8.0-101 (--remove):
 subprocess installed post-removal script returned error exit status 127
 jdk1.8.0-101
I think I lack the folders because i manually remove it myself.
Son Sonas
Looks like you have a package in an inconsistent state which prevents you from installing anything.
You could try answers in this question, replacing linux-headers-3.0.0-19 with jdk1.8.0-101, see if it helps.
It's probably a good idea to reinstall the package properly afterwards (chances are something depends on it ...)
lemonsqueeze
  • 1,664
