TL; DR
How do I re-map ALT R to work as ALT R instead of ALT Gr on Ubuntu 20.04?
Details
As described in another post, I've executed xev at Ubuntu 20.04 in order to discover ALT L and ALT R keycodes:
  • ALT L keycode 64 (keysym 0xffe9, Alt_L)
  • ALT R keycode 108 (keysym 0xfe03, ISO_Level3_Shift)
Running xmodmap -pke > ~/.Xmodmap, the following configuration was saved:
keycode  64 = Alt_L Meta_L Alt_L Meta_L Alt_L Meta_L
keycode 108 = ISO_Level3_Shift NoSymbol ISO_Level3_Shift NoSymbol ISO_Level3_Shift
while gsettings provides:
$ gsettings get org.gnome.desktop.input-sources xkb-options
['lv3:menu_switch']
Theoretically re-mapping 108 at ~/.Xmodmap should be enough:
keycode 108 = Alt_R Meta_R Alt_R Meta_R Alt_R Meta_R
However, even running xmodmap ~/.Xmodmap and also saving this command at ~/.xinitrc, the modifications did not take effect immediately or after login again at Ubuntu.
Thus it is not possible to execute extensible commands in Emacs using ALT R + X at Emacs
So what is the proper way of changing ALT R behavior?
References:
