I am on the latest LTS (Ubuntu 18.04.04)
After running an update, nouveau or fbdev is causing problems. X.Org X Server 1.20.5
Whenever I try to Enter System Settings, Ubuntu logs me out.
I have gone through these questions
Ubuntu 18.04 opening system setting logs me out
Dont want to install nvidia drivers yet
Ubuntu 18.10 opening system settings logs me out (Intel graphic card)
Ubuntu 18.04 opening system settings logs me out
Dont want to do dist-upgrade (this will insatll Ubuntu 20, which is not LTS yet)
Previous to the update under Settings -> Devices -> Color
I did change the default Color Profile to "Sunday 23 July 2017 - D55"
systemd[3357]: gnome-terminal-server.service: Main process exited, code=exited, status=1/FAILURE
systemd[3357]: gnome-terminal-server.service: Failed with result 'exit-code'.
gsd-color[2748]: failed to connect to device: Failed to connect to missing device /org/freedesktop/ColorManager/devices/xrandr_BOE_XT_32S7100F_ritin_1000
Have tried Ubuntu Recovery and it does log me in and am able to go into settings.
but with reduced screen size (1024x768)
I fail to understand why it worked fine on Ubuntu 16, 18.04, 18.04.04
but soon after the update it started causing problems
I am pretty sure installing nvidia drivers would solve the issue.
but why is Xorg not working and is there a way to reset/revert nouveau?
Thanks
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.4 LTS
Release:    18.04
Codename:   bionic
$ inxi -SCG
System:    Host: ritin-hexacore Kernel: 5.3.0-42-generic x86_64 bits: 64 Desktop: Gnome 3.28.4
           Distro: Ubuntu 18.04.4 LTS
CPU:       6 core Intel Core i7-8700K (-MT-MCP-) cache: 12288 KB
           clock speeds: max: 4700 MHz 1: 800 MHz 2: 800 MHz 3: 800 MHz 4: 800 MHz 5: 800 MHz 6: 800 MHz
           7: 802 MHz 8: 800 MHz 9: 800 MHz 10: 800 MHz 11: 800 MHz 12: 800 MHz
Graphics:  Card: NVIDIA GP107 [GeForce GTX 1050 Ti]
           Display Server: x11 (X.Org 1.20.5 ) drivers: fbdev,nouveau (unloaded: modesetting,vesa)
           Resolution: 1920x1080@60.00hz
           OpenGL: renderer: llvmpipe (LLVM 9.0, 256 bits) version: 3.3 Mesa 19.2.8
$ xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x46 cap: 0x0 crtcs: 4 outputs: 3 associated providers: 0 name:modesetting
$ sudo apt list | grep fbdev
kwin-wayland-backend-fbdev/bionic-updates 4:5.12.9.1-0ubuntu0.1 amd64
libomxil-bellagio0-components-fbdevsink/bionic 0.1-2ubuntu2 amd64
xserver-xorg-video-fbdev/bionic 1:0.4.4-1build6 amd64
xserver-xorg-video-fbdev-hwe-16.04/bionic 3:14.1 amd64
xserver-xorg-video-fbdev-hwe-18.04/bionic-updates,now 1:0.5.0-1ubuntu1~18.04.1 amd64 [installed]
$ sudo apt list | grep nouveau
libdrm-nouveau2/bionic-updates,bionic-security,now 2.4.99-1ubuntu1~18.04.2 amd64 [installed]
nouveau-firmware/bionic,bionic 20091212-0ubuntu1 all
xserver-xorg-video-nouveau/bionic 1:1.0.15-2 amd64
xserver-xorg-video-nouveau-hwe-16.04/bionic 3:14.1 amd64
xserver-xorg-video-nouveau-hwe-16.04-dbg/bionic 3:14.1 amd64
xserver-xorg-video-nouveau-hwe-18.04/bionic-updates,now 1:1.0.16-1~18.04.1 amd64 [installed]
$ sudo lshw -C display
  *-display
       description: VGA compatible controller
       product: GP107 [GeForce GTX 1050 Ti]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
       configuration: driver=nouveau latency=0
       resources: irq:140 memory:a2000000-a2ffffff memory:90000000-9fffffff memory:a0000000-a1ffffff ioport:3000(size=128) memory:c0000-dffff
log_file: /var/log/gpu-manager.log  (trimmed)
last_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
new_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
can't access /run/u-d-c-nvidia-was-loaded file
can't access /opt/amdgpu-pro/bin/amdgpu-pro-px
Is nvidia loaded? no
Was nvidia unloaded? no
Is nvidia blacklisted? no
Is nouveau loaded? yes
Is nouveau blacklisted? no
Is nvidia kernel module available? no
Vendor/Device Id: 10de:1c82
BusID "PCI:1@0:0:0"
Is boot vga? yes
Skipping "/dev/dri/card0", driven by "nouveau"
Found "/dev/dri/card0", driven by "nouveau"
output 0:
        card0-HDMI-A-1
Number of connected outputs for /dev/dri/card0: 1
Does it require offloading? no
Has nvidia? yes
How many cards? 1
Has the system changed? No
Single card detected
Nothing to do
//-------------------------------cat Xorg.0.log -------
X Protocol Version 11, Revision 0
[  2741.202] Build Operating System: Linux 4.4.0-170-generic x86_64 Ubuntu
[  2741.202] Current Operating System: Linux ritin-hexacore 5.3.0-42-generic #34~18.04.1-Ubuntu SMP Fri Feb 28 13:42:26 UTC 2020 x86_64
[  2741.202] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.3.0-42-generic root=UUID=adefd3f7-bf2a-4c2d-8286-965f92a12062 ro quiet splash vt.handoff=1
[  2741.202] Build Date: 18 December 2019  08:15:29AM
[  2741.202] xorg-server-hwe-18.04 2:1.20.5+git20191008-0ubuntu1~18.04.1 (For technical support please see http://www.ubuntu.com/support)
[  2741.202] Current version of pixman: 0.34.0
[  2741.228] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_38
[  2741.232] (II) xfree86: Adding drm device (/dev/dri/card0)
[  2741.237] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[  2741.247] (--) PCI:*(1@0:0:0) 10de:1c82:1462:8c96 rev 161, Mem @ 0xa2000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/131072
[  2741.247] (II) LoadModule: "glx"
[  2741.248] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  2741.250] (II) Module glx: vendor="X.Org Foundation"
[  2741.250]    compiled for 1.20.5, module version = 1.0.0
[  2741.250]    ABI class: X.Org Server Extension, version 10.0
[  2741.435] (==) Matched modesetting as autoconfigured driver 0
[  2741.435] (==) Matched fbdev as autoconfigured driver 1
[  2741.435] (==) Matched vesa as autoconfigured driver 2
[  2741.435] (==) Assigned the driver to the xf86ConfigLayout
ABI class: X.Org Video Driver, version 24.0
//----  /var/log/syslog
Mar 30 10:21:23 ritin-hexacore /usr/lib/gdm3/gdm-x-session[10795]: X.Org X Server 1.20.5
Mar 30 10:21:23 ritin-hexacore /usr/lib/gdm3/gdm-x-session[10795]: X Protocol Version 11, Revision 0
Mar 30 10:21:23 ritin-hexacore /usr/lib/gdm3/gdm-x-session[10795]: Build Operating System: Linux 4.4.0-170-generic x86_64 Ubuntu
Mar 30 10:21:23 ritin-hexacore /usr/lib/gdm3/gdm-x-session[10795]: Current Operating System: Linux ritin-hexacore 5.3.0-42-generic #34~18.04.1-Ubuntu SMP Fri Feb 28 13:42:26 UTC 2020 x86_64
Mar 30 10:21:23 ritin-hexacore /usr/lib/gdm3/gdm-x-session[10795]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.3.0-42-generic root=UUID=adefd3f7-bf2a-4c2d-8286-965f92a12062 ro quiet splash vt.handoff=1
Mar 30 10:21:23 ritin-hexacore /usr/lib/gdm3/gdm-x-session[10795]: Build Date: 18 December 2019  08:15:29AM
Mar 30 10:21:23 ritin-hexacore /usr/lib/gdm3/gdm-x-session[10795]: xorg-server-hwe-18.04 2:1.20.5+git20191008-0ubuntu1~18.04.1 (For technical support please see http://www.ubuntu.com/support)
Mar 30 10:21:23 ritin-hexacore /usr/lib/gdm3/gdm-x-session[10795]: Current version of pixman: 0.34.0
//-------------------------------  /var/log/syslog (looking for nouveau/fbdev)
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (WW) Falling back to old probe method for fbdev
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Loading sub module "fbdevhw"
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) LoadModule: "fbdevhw"
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Module fbdevhw: vendor="X.Org Foundation"
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: #011compiled for 1.20.5, module version = 0.0.2
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: #011ABI class: X.Org Video Driver, version 24.0
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) open /dev/fb0: Permission denied
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Creating default Display subsection in Screen section
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: #011"Default Screen Section" for depth/fbbpp 24/32
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (==) modeset(0): Depth 24, (==) framebuffer bpp 32
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (==) modeset(0): RGB weight 888
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (==) modeset(0): Default visual is TrueColor
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Loading sub module "glamoregl"
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) LoadModule: "glamoregl"
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Loading /usr/lib/xorg/modules/libglamoregl.so
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Module glamoregl: vendor="X.Org Foundation"
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: #011compiled for 1.20.5, module version = 1.0.1
Mar 30 09:55:14 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: #011ABI class: X.Org ANSI C Emulation, version 0.4
Mar 30 09:55:15 ritin-hexacore gnome-shell[2089]: clutter_input_device_get_device_type: assertion 'CLUTTER_IS_INPUT_DEVICE (device)' failed
Mar 30 09:55:15 ritin-hexacore gnome-shell[2089]: JS ERROR: TypeError: device is null#012_init/<@resource:///org/gnome/shell/ui/keyboard.js:619:1
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: nvc0_screen_create:1107 - Error allocating PGRAPH context for M2MF: -16
Mar 30 09:55:15 ritin-hexacore kernel: [  652.187430] nouveau 0000:01:00.0: gr: FECS falcon already acquired by gr!
Mar 30 09:55:15 ritin-hexacore kernel: [  652.187439] nouveau 0000:01:00.0: gr: init failed, -16
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Refusing to try glamor on llvmpipe
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) modeset(0): glamor initialization failed
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): ShadowFB: preferred YES, enabled YES
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Double-buffered shadow updates: off
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Output DVI-D-1 has no monitor section
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Output HDMI-1 has no monitor section
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Output DP-1 has no monitor section
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): EDID for output DVI-D-1
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): EDID for output HDMI-1
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Manufacturer: BOE  Model: 10  Serial#: 0
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Year: 2016  Week: 15
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): EDID Version: 1.3
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Digital Display Input
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Max Image Size [cm]: horiz.: 70  vert.: 39
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Gamma: 1.00
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): No DPMS capabilities specified
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: #011ABI class: X.Org ANSI C Emulation, version 0.4
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) UnloadModule: "fbdev"
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Unloading fbdev
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) UnloadSubModule: "fbdevhw"
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Unloading fbdevhw
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) UnloadModule: "vesa"
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Unloading vesa
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (==) modeset(0): Backing store enabled
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (==) modeset(0): Silken mouse enabled
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (==) modeset(0): DPMS enabled
Mar 30 09:55:15 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) Initializing extension Generic Event Extension
Mar 30 09:55:16 ritin-hexacore gnome-session[3410]: gnome-session-check-accelerated: GL Helper exited with code 512
Mar 30 09:55:16 ritin-hexacore gnome-session[3410]: libEGL warning: DRI2: failed to authenticate
Mar 30 09:55:16 ritin-hexacore gnome-session[3410]: gnome-session-check-accelerated: GLES Helper exited with code 512
Mar 30 09:55:16 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: Could not parse desktop file mate-power-ma
nager.desktop or it references a not found TryExec binary
Mar 30 09:55:16 ritin-hexacore gnome-session-binary[3410]: WARNING: Could not parse desktop file mate-power-manager.desktop or it r
Mar 30 09:55:17 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: Could not parse desktop file mate-screensa
ver.desktop or it references a not found TryExec binary
Mar 30 09:55:17 ritin-hexacore gnome-session-binary[3410]: WARNING: Could not parse desktop file mate-screensaver.desktop or it ref
Mar 30 09:55:17 ritin-hexacore gnome-keyring-ssh.desktop[3566]: SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
Mar 30 09:55:17 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): EDID vendor "BOE", prod id 16
Mar 30 09:55:17 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Using EDID range info for horizontal sync
Mar 30 09:55:17 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Using EDID range info for vertical refresh
Mar 30 09:55:17 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Printing DDC gathered Modelines:
Mar 30 09:55:17 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052
 2200  1080 1084 1089 1125 +hsync -vsync (67.5 kHz eP)
Mar 30 09:55:17 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536
1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
Mar 30 09:55:17 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430
1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
Mar 30 09:55:26 ritin-hexacore systemd[3357]: Starting flatpak document portal service...
Mar 30 09:55:26 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): EDID vendor "BOE", prod id 16
Mar 30 09:55:26 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Using hsync ranges from config file
Mar 30 09:55:26 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Using vrefresh ranges from config file
Mar 30 09:55:26 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Printing DDC gathered Modelines:
Mar 30 09:55:26 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync -vsync (67.5 kHz eP)
Mar 30 10:21:04 ritin-hexacore gnome-control-center.desktop[10711]: nvc0_screen_create:1107 - Error allocating PGRAPH context for M2MF: -16
Mar 30 10:21:04 ritin-hexacore kernel: [ 2201.289520] nouveau 0000:01:00.0: gr: FECS falcon already acquired by gr!
Mar 30 10:21:04 ritin-hexacore kernel: [ 2201.289524] nouveau 0000:01:00.0: gr: init failed, -16
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: Xorg: ../../../../../../include/privates.h:121: dixGetPrivateAddr: Assertion `key->initialized' failed.
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE)
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) Backtrace:
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 0: /usr/lib/xorg/Xorg (OsLookupColor+0x139) [0x55ac775d17d9]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 1: /lib/x86_64-linux-gnu/libpthread.so.0 (funlockfile+0x50) [0x7f6b8a93b8df]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 2: /lib/x86_64-linux-gnu/libc.so.6 (gsignal+0xc7) [0x7f6b8a576e97]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 3: /lib/x86_64-linux-gnu/libc.so.6 (abort+0x141) [0x7f6b8a578801]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 4: /lib/x86_64-linux-gnu/libc.so.6 (uselocale+0x33a) [0x7f6b8a56858a]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 5: /lib/x86_64-linux-gnu/libc.so.6 (__assert_fail+0x42) [0x7f6b8a568412]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 6: /usr/lib/xorg/Xorg (SProcXkbDispatch+0x7c7) [0x55ac774608af]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 7: /usr/lib/xorg/Xorg (DRI2Authenticate+0x93) [0x55ac7759ecf3]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 8: /usr/lib/xorg/Xorg (DRI2GetParam+0x713) [0x55ac7759fe33]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 9: /usr/lib/xorg/Xorg (SendErrorToClient+0x368) [0x55ac774745a8]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 10: /usr/lib/xorg/Xorg (InitFonts+0x3c8) [0x55ac77478578]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 11: /lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main+0xe7) [0x7f6b8a559b97]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) 12: /usr/lib/xorg/Xorg (_start+0x2a) [0x55ac774621ea]
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: Fatal server error:
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) Caught signal 6 (Aborted). Server aborting
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: Please consult the The X.Org Foundation support
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: #011 at http://wiki.x.org
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]:  for help.
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) Please also check the log file at "/home/ritin/.local/share/xorg/Xorg.0.log" for additional information.
Mar 30 10:21:04 ritin-hexacore /usr/lib/gdm3/gdm-x-session[3375]: (EE) Server terminated with error (1). Closing log file.
Mar 30 10:21:10 ritin-hexacore gnome-control-center.desktop[10711]: XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
Mar 30 10:21:10 ritin-hexacore gnome-control-center.desktop[10711]:       after 11 requests (11 known processed) with 0 events remaining.
Mar 30 10:21:10 ritin-hexacore update-notifier[5358]: update-notifier: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore alarm-clock-applet.desktop[3885]: alarm-clock-applet: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore org.gnome.Shell.desktop[3571]: [4553:4553:0330/102110.565177:ERROR:x11_util.cc(109)] X IO error received (X server probably went away)
Mar 30 10:21:10 ritin-hexacore org.gnome.Shell.desktop[3571]: [4159:4159:0330/102110.565393:ERROR:chrome_browser_main_extra_parts_x11.cc(62)] X IO error received (X server probably went away)
Mar 30 10:21:10 ritin-hexacore gnome-terminal-[4195]: gnome-terminal-server: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore gsd-media-keys[3773]: gsd-media-keys: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore nautilus-deskto[3875]: nautilus-desktop: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore indicator-senso[3893]: indicator-sensors: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore gsd-keyboard[3772]: gsd-keyboard: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore gsd-clipboard[3766]: gsd-clipboard: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore gsd-wacom[3745]: gsd-wacom: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore gsd-color[3767]: gsd-color: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore gsd-power[3726]: gsd-power: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.MediaKeys.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Clipboard.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.MediaKeys.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Clipboard.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gsd-xsettings[3744]: gsd-xsettings: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Mar 30 10:21:10 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Power.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Power.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore bluetoothd[1301]: Endpoint unregistered: sender=:1.99 path=/MediaEndpoint/A2DPSource
Mar 30 10:21:10 ritin-hexacore bluetoothd[1301]: Endpoint unregistered: sender=:1.99 path=/MediaEndpoint/A2DPSink
Mar 30 10:21:10 ritin-hexacore systemd[3357]: gnome-terminal-server.service: Main process exited, code=exited, status=1/FAILURE
Mar 30 10:21:10 ritin-hexacore systemd[3357]: gnome-terminal-server.service: Failed with result 'exit-code'.
Mar 30 10:21:10 ritin-hexacore gsd-color[2748]: failed to connect to device: Failed to connect to missing device /org/freedesktop/ColorManager/devices/xrandr_BOE_XT_32S7100F_ritin_1000
Mar 30 10:21:10 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.XSettings.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Wacom.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Color.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Keyboard.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.XSettings.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Wacom.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Color.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.SettingsDaemon.Keyboard.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore org.gnome.SettingsDaemon.Clipboard.desktop[10744]: Cannot open display:
Mar 30 10:21:10 ritin-hexacore org.gnome.SettingsDaemon.MediaKeys.desktop[10743]: Cannot open display:
Mar 30 10:21:10 ritin-hexacore org.gnome.SettingsDaemon.Wacom.desktop[10754]: Cannot open display:
Mar 30 10:21:10 ritin-hexacore org.gnome.SettingsDaemon.XSettings.desktop[10757]: Cannot open display:
Mar 30 10:21:10 ritin-hexacore org.gnome.SettingsDaemon.Power.desktop[10755]: Cannot open display:
Mar 30 10:21:10 ritin-hexacore org.gnome.Shell.desktop[3571]: xcb_connection_has_error() returned true
Mar 30 10:21:10 ritin-hexacore pulseaudio[10762]: [pulseaudio] client-conf-x11.c: xcb_connection_has_error() returned true
Mar 30 10:21:10 ritin-hexacore rtkit-daemon[2436]: Successfully made thread 10765 of process 10765 (n/a) owned by '1000' high priority at nice level -11.
Mar 30 10:21:10 ritin-hexacore rtkit-daemon[2436]: Supervising 1 threads of 1 processes of 1 users.
Mar 30 10:21:10 ritin-hexacore pulseaudio[10765]: [pulseaudio] pid.c: Stale PID file, overwriting.
Mar 30 10:21:10 ritin-hexacore gnome-control-center.desktop[10711]: nvc0_screen_create:1107 - Error allocating PGRAPH context for M2MF: -16
Mar 30 10:21:10 ritin-hexacore kernel: [ 2207.720702] nouveau 0000:01:00.0: gr: FECS falcon already acquired by gr!
Mar 30 10:21:10 ritin-hexacore kernel: [ 2207.720741] nouveau 0000:01:00.0: gr: init failed, -16
Mar 30 10:21:10 ritin-hexacore kernel: [ 2207.768514] nouveau 0000:01:00.0: gr: FECS falcon already acquired by gr!
Mar 30 10:21:10 ritin-hexacore kernel: [ 2207.768613] nouveau 0000:01:00.0: gr: init failed, -16
Mar 30 10:21:10 ritin-hexacore gnome-control-c[10711]: gnome-control-center: Fatal IO error 0 (Success) on X server :0.
Mar 30 10:21:10 ritin-hexacore at-spi-bus-launcher[3522]: XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
Mar 30 10:21:10 ritin-hexacore at-spi-bus-launcher[3522]:       after 2431 requests (2431 known processed) with 0 events remaining.
Mar 30 10:21:10 ritin-hexacore gnome-shell[3571]: gnome-shell: Fatal IO error 4 (Interrupted system call) on X server :0.
Mar 30 10:21:10 ritin-hexacore psensor[4507]: psensor: Fatal IO error 0 (Success) on X server :0.
Mar 30 10:21:10 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.Shell.desktop' exited with code 1
Mar 30 10:21:10 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.Shell.desktop' exited with code 1
Mar 30 10:21:11 ritin-hexacore gnome-shell[10776]: Failed to create backend: Unable to open display ':0'
Mar 30 10:21:11 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.Shell.desktop' exited with code 1
Mar 30 10:21:11 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: WARNING: App 'org.gnome.Shell.desktop' respawning too quickly
Mar 30 10:21:11 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.Shell.desktop' exited with code 1
Mar 30 10:21:11 ritin-hexacore gnome-session-binary[3410]: Unrecoverable failure in required component org.gnome.Shell.desktop
Mar 30 10:21:11 ritin-hexacore gnome-session[3410]: gnome-session-binary[3410]: CRITICAL: We failed, but the fail whale is dead. Sorry....
Mar 30 10:21:11 ritin-hexacore gnome-session-binary[3410]: WARNING: App 'org.gnome.Shell.desktop' respawning too quickly
Mar 30 10:21:11 ritin-hexacore gnome-session-binary[3410]: CRITICAL: We failed, but the fail whale is dead. Sorry....
Mar 30 10:21:11 ritin-hexacore kernel: [ 2208.118658] rfkill: input handler enabled
Mar 30 10:21:11 ritin-hexacore pulseaudio[10765]: [pulseaudio] module-alsa-card.c: Failed to open mixer for jack detection
Mar 30 10:21:11 ritin-hexacore pulseaudio[10765]: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.AccessDenied: Rejected send message, 2 matched rules; type="method_call", sender=":1.148" (uid=1000 pid=10765 comm="/usr/bin/pulseaudio --start --log-target=syslog " label="unconfined") interface="org.freedesktop.DBus.ObjectManager" member="GetManagedObjects" error name="(unset)" requested_reply="0" destination="org.bluez" (uid=0 pid=1301 comm="/usr/lib/bluetooth/bluetoothd " label="unconfined")
ritin
  • 181
