Disclaimer
I know there is a couple of similar questions but all of them seem to have trouble with NVIDIA graphics. However, I have a built-in Intel graphics.
The problem
Whenever I try to open system settings, the system logs me out. After re-login, all the applications I had open are closed (i.e. this is really log-out, not just locking the screen).
Solutions I have tried
- NVIDIA drivers issues: as I said, I don't use an NVIDIA graphics card
- remove
.Xauthorityfolder: I don't have this folder
System info
This is a desktop PC with ASRock Z390 Extreme 4 motherboard. The only external hardware connected is an external WiFi adapter.
Output of sudo inxi -SCG:
System:
Host: mypc Kernel: 4.18.0-13-generic x86_64 bits: 64
Desktop: Gnome 3.30.1 Distro: Ubuntu 18.10 (Cosmic Cuttlefish)
CPU:
Topology: 6-Core model: Intel Core i5-9600K bits: 64 type: MCP
L2 cache: 9216 KiB
Speed: 800 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 1036 2: 873
3: 1265 4: 850 5: 1319 6: 1068
Graphics:
Device-1: Intel driver: i915 v: kernel
Display: x11 server: X.Org 1.20.1 driver: i915 resolution: 3840x2160~30Hz
OpenGL: renderer: llvmpipe (LLVM 7.0 256 bits) v: 3.3 Mesa 18.2.2
UPD
I also tried to run gnome-control-center &> before-log-out.log and this is the contents of the file I have after having logged back in:
XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
after 11 requests (11 known processed) with 0 events remaining.
UPD2
If I log in with Wayland, I can open settings without any problem. The output of inxi -SCG is the same with the only difference: Display: wayland.
However, on Wayland the system is much slower (even the mouse movements are noticeably irregular). This issue is posted as a separate question.
