I just installed Ubuntu 19.10 and I have no sound at all. I know my hardware is working because I heard system sounds when I was booting from a USB to install Ubuntu. When I go to system sound settings all I can see is a dummy output, with no option to change it.
Some other relevant information:
  • I cannot open alsamixer, even with sudo, it returns
"cannot open mixer: No such file or directory"
  • Here is the output from 'sudo lspci -vv | grep -i audio'
"""00:1f.3 Multimedia audio controller: Intel Corporation Cannon Point-LP High Definition Audio Controller (rev 11) Subsystem: Hewlett-Packard Company Cannon Point-LP High Definition Audio Controller"""
  • Here is the output from "sudo dmesg | grep -i audio"
"[ 0.416732] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio) [ 3.181791] snd_soc_skl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915]) [ 3.210073] skl_hda_dsp_generic skl_hda_dsp_generic: Unsupported HDAudio/iDisp configuration found"
  • Only dummy output shows up in pavucontrol
  • "cat /proc/asound/cards" produces
"--- no soundcards ---"
Outputs of uname -a, lspci and inxi are pasted below. If anyone would be able to me a hand with this that would be amazing. Apologies for any mistakes I am a linux newbie, just started using it for bioinformatics. If you need any other information that might help just give me a shout!
uname -a
Linux harry-HP-EliteBook-850-G6 5.3.0-42-generic #34-Ubuntu SMP Fri Feb 28 05:49:40 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
inxi
CPU: Quad Core Intel Core i5-8365U (-MT MCP-) speed/min/max: 800/400/4100 MHz Kernel: 5.3.0-42-generic x86_64 Up: 21m Mem: 1580.9/31925.3 MiB (5.0%) Storage: 476.94 GiB (1.7% used) Procs: 268 Shell: bash 5.0.3 inxi: 3.0.36
lspci
00:00.0 Host bridge: Intel Corporation Device 3e34 (rev 0c) 00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (Whiskey Lake) (rev 02) 00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c) 00:12.0 Signal processing controller: Intel Corporation Cannon Point-LP Thermal Controller (rev 11) 00:14.0 USB controller: Intel Corporation Cannon Point-LP USB 3.1 xHCI Controller (rev 11) 00:14.2 RAM memory: Intel Corporation Cannon Point-LP Shared SRAM (rev 11) 00:15.0 Serial bus controller [0c80]: Intel Corporation Cannon Point-LP Serial IO I2C Controller #0 (rev 11) 00:15.1 Serial bus controller [0c80]: Intel Corporation Cannon Point-LP Serial IO I2C Controller #1 (rev 11) 00:16.0 Communication controller: Intel Corporation Cannon Point-LP MEI Controller #1 (rev 11) 00:16.3 Serial controller: Intel Corporation Device 9de3 (rev 11) 00:1c.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #5 (rev f1) 00:1c.7 PCI bridge: Intel Corporation Device 9dbf (rev f1) 00:1d.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #13 (rev f1) 00:1f.0 ISA bridge: Intel Corporation Cannon Point-LP LPC Controller (rev 11) 00:1f.3 Multimedia audio controller: Intel Corporation Cannon Point-LP High Definition Audio Controller (rev 11) 00:1f.4 SMBus: Intel Corporation Cannon Point-LP SMBus Controller (rev 11) 00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Point-LP SPI Controller (rev 11) 00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (6) I219-LM (rev 11) 01:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06) 02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06) 02:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06) 02:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06) 03:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 2C 2018] (rev 06) 39:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 2C 2018] (rev 06) 3a:00.0 Network controller: Intel Corporation Device 2723 (rev 1a) 3b:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
A citation from another site:
sudo modprobe -v snd-hda-intel
sudo modprobe -v snd-soc-skl-hda-dsp
sudo alsa force-reload
This might solve your problem but I am not sure I can't confirm it.
