My Bluetooth adapter does not work in Ubuntu.
$ lsusb | grep tooth
Bus 002 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
$ hciconfig
hci0: Type: Primary Bus: USB
BD Address: 33:03:30:09:74:B4 ACL MTU: 360:4 SCO MTU: 0:0
DOWN
RX bytes:1106 acl:0 sco:0 events:56 errors:0
TX bytes:736 acl:0 sco:0 commands:60 errors:0
$ sudo hciconfig hci0 up
Can't init device hci0: Operation not supported (95)
$ bluetoothctl
Agent registered
[bluetooth]# power on
No default controller available
$ hcitool dev
Devices:
$ rfkill
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 unblocked unblocked
1 wlan phy0 unblocked unblocked
Tried the last two actions:
Bluetake
Works out-of-the-box in Ubuntu v10.04 ~ 11.04 but stopped working reliably in 11.10, frequent kernel panics and other general not good stuff, [Bug: 901770]
$ lsusb <br>Bus 007 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
$ hciconfig -a hci0 <br>Manufacturer: Cambridge Silicon Radio (10)Might need same fix as Belkin : add
blacklist hci_usbto/etc/modprobe.d/blacklist.conf, and addhci_usb reset=1to/etc/modules
Also tried
- to install kernel 5.5.2 kernel. But it failed to login, so I've purged it and returned to my
5.3.0-29-generickernel. - to do the next, but it failed:
$ make -C /lib/modules/$(uname -r)/build M=$PWD modules make: Entering directory '/usr/src/linux-headers-5.3.0-29-generic' CC [M] /home/spacer/kernel/bluetooth/hci_vhci.o /home/spacer/kernel/bluetooth/hci_vhci.c: In function ‘vhci_create_device’: /home/spacer/kernel/bluetooth/hci_vhci.c:134:2: warning: dereferencing ‘void *’ pointer 134 | *skb_put(skb, 1) = 0xff; | ^~~~~~~~~~~~~~~~ /home/spacer/kernel/bluetooth/hci_vhci.c:134:19: error: invalid use of void expression 134 | *skb_put(skb, 1) = 0xff; | ^ /home/spacer/kernel/bluetooth/hci_vhci.c:135:2: warning: dereferencing ‘void *’ pointer 135 | *skb_put(skb, 1) = dev_type; | ^~~~~~~~~~~~~~~~ /home/spacer/kernel/bluetooth/hci_vhci.c:135:19: error: invalid use of void expression 135 | *skb_put(skb, 1) = dev_type; | ^ /home/spacer/kernel/bluetooth/hci_vhci.c: In function ‘vhci_get_user’: /home/spacer/kernel/bluetooth/hci_vhci.c:203:19: error: ‘HCI_BREDR’ undeclared (first use in this function) 203 | if (dev_type != HCI_BREDR && dev_type != HCI_AMP) | ^~~~~~~~~ /home/spacer/kernel/bluetooth/hci_vhci.c:203:19: note: each undeclared identifier is reported only once for each function it appears in /home/spacer/kernel/bluetooth/hci_vhci.c: In function ‘vhci_open_timeout’: /home/spacer/kernel/bluetooth/hci_vhci.c:307:43: error: ‘HCI_BREDR’ undeclared (first use in this function) 307 | vhci_create_device(data, amp ? HCI_AMP : HCI_BREDR); | ^~~~~~~~~ /home/spacer/kernel/bluetooth/hci_vhci.c: At top level: /home/spacer/kernel/bluetooth/hci_vhci.c:352:3: error: ‘const struct file_operations’ has no member named ‘aio_write’ 352 | .aio_write = vhci_write, | ^~~~~~~~~ /home/spacer/kernel/bluetooth/hci_vhci.c:352:15: error: positional initialization of field in ‘struct’ declared with ‘designated_init’ attribute [-Werror=designated-init] 352 | .aio_write = vhci_write, | ^~~~~~~~~~ /home/spacer/kernel/bluetooth/hci_vhci.c:352:15: note: (near initialization for ‘vhci_fops’) /home/spacer/kernel/bluetooth/hci_vhci.c:352:15: error: initialization of ‘ssize_t (*)(struct file *, const char *, size_t, loff_t *)’ {aka ‘long int (*)(struct file *, const char *, long unsigned int, long long int *)’} from incompatible pointer type ‘ssize_t (*)(struct kiocb *, const struct iovec *, long unsigned int, loff_t)’ {aka ‘long int (*)(struct kiocb *, const struct iovec *, long unsigned int, long long int)’} [-Werror=incompatible-pointer-types] /home/spacer/kernel/bluetooth/hci_vhci.c:352:15: note: (near initialization for ‘vhci_fops.write’) cc1: some warnings being treated as errors make[1]: *** [scripts/Makefile.build:290: /home/spacer/kernel/bluetooth/hci_vhci.o] Error 1 make: *** [Makefile:1655: _module_/home/spacer/kernel/bluetooth] Error 2 make: Leaving directory '/usr/src/linux-headers-5.3.0-29-generic'
