I've bought a Bluetooth USB which works ok in Windows (dual boot), but not in my Ubuntu.
$ sudo systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
     Active: active (running) since Sat 2021-12-25 01:46:33 -03; 21h ago
       Docs: man:bluetoothd(8)
   Main PID: 719 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 38375)
     Memory: 1.5M
     CGroup: /system.slice/bluetooth.service
             └─719 /usr/lib/bluetooth/bluetoothd
dez 25 01:46:33 g-Z390-M systemd[1]: Starting Bluetooth service... dez 25 01:46:33 g-Z390-M bluetoothd[719]: Bluetooth daemon 5.53 dez 25 01:46:33 g-Z390-M systemd[1]: Started Bluetooth service. dez 25 01:46:33 g-Z390-M bluetoothd[719]: Starting SDP server dez 25 01:46:33 g-Z390-M bluetoothd[719]: Bluetooth management interface 1.19 initialized
but when using blueman, I get the following
$ blueman-manager
blueman-manager version 2.1.2 starting
Failed to enable bluetooth
blueman-manager 22.59.46 ERROR    Manager:118 on_dbus_name_appeared: Default adapter not found, trying first available.
blueman-manager 22.59.46 ERROR    Manager:122 on_dbus_name_appeared: No adapter(s) found, exiting
I'm using Ubuntu 20.04.3 LTS with kernel 5.11.0-43-generic. The following holds
$ lsmod | grep -i blu
bluetooth             638976  12 btrtl,btintel,btbcm,bnep,btusb
ecdh_generic           16384  1 bluetoot
$ sudo rfkill list 0: hci0: Bluetooth Soft blocked: no Hard blocked: no
$ lsusb Bus 001 Device 004: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
waaat
