I currently have a Dell Vostro 14 5490. I have trued using Ubuntu 18.04 LTS, but a lot of my hardware is not supported on that release. So instead, I've decided to use Ubuntu 19.10 which works with my hardware (seemingly except for my graphics card or something).
My issue is that whenever I boot into Ubuntu 19.10 I am able to use it but after a short amount of time (10 seconds or so) the operation of the OS mostly freezes. To be more specific, I am able to move my mouse and when I type on my keyboard it lights up, but I am not able to click anything and when I mouse over things they are not highlighted.
It might also be worth noting that I am currently booting from a "try Ubuntu without installing" option whenever I installed the ISO file onto a USB drive using Rufus. Also, it does work fine when I boot it in safe graphics mode. This gives me the impression that something may be wrong with how Ubuntu 19.10 is interfacing with my GPU. Thanks for any help in advance!
xorist
  • 107
We must make sure that you don't have Nvidia's proprietary driver installed (or any installed pieces of it).
Nvidia's proprietary driver tend to cause problems (aka bugs) in general i noticed mostly happening when is installed with Gnome3 (on Ubuntu) even with Ubuntu's login screen (after login), this does not apply to everyone.
Boot until you see the login screen but don't login.
Press:
Ctrl+Alt+F1
and type you password.
To trace and remove any possible installed pieces of Nvidia even after proper removal done in the past by the Nvidia's uninstaller or even some possible auto-installed portion of it.
Type the followings:
sudo service lightdm stop
sudo nvidia-uninstall
sudo apt purge nvidia*
sudo apt update
sudo apt install mesa-utils nouveau*
sudo reboot
Keep in mind:
If you definitely willing to install at some point the Nvidia's proprietary driver try to install their latest from their website (at your own risk).
Worst case scenario if everything fails:
  1. Install and try a different UI (for ex. xfce) but like i said again you should also aware that Ubuntu's login screen (after login) may also cause problems with the proprietary driver even with other UI's.
  2. Try to live boot to a different Ubuntu base distribution (for ex. Xubuntu) which includes a different login screen.
https://www.youtube.com/watch?v=MShbP3OpASA&t=49m53s
I have the same MX series GPU which is similar to yours (MX110) on my laptop but i use a different distribution and UI (xfce) with graphic driver Nouveau (free open source) which i always prefer.
You might try installing this BIOS update from Dell to see if that helps at all. I believe you should be able to install this in safe graphics mode.
https://www.dell.com/support/home/us/en/04/product-support/product/vostro-14-5490-laptop/drivers Specifically: https://dl.dell.com/FOLDER06046211M/1/Inspiron_5490_5498_5590_5598_Vostro_5490_5590_1.5.1.exe
You might also try 18.04 - LTS releases can be a bit less flaky in my experience.
Chris
  • 143
Check your Service Manual
  • Ensure items such as TPM are turned off.
  • All other BIOS options google the option + Linux to see what settings should be.
