Microsoft has made this nifty tool called Windows Subsystem for Linux. WSL2 creates a lightweight VM running Linux (in this case Ubuntu) to facilitate using Linux on Windows.
Within WSL2 (Ubuntu) I've run: sudo nano ~/.ssh/id_rsa.pub. I attempt to use the normal nano method for copying. I can't then paste it on the Windows side.
Ends up WSL2 has its own key combination for copying/pasting between Linux/Windows and that you need to enable it within WSL.
I enable the function within WSL and use Ctrl+Shift+C to copy the text as instructed. Ctrl+Shift+V into a windows app does nothing.
I use the regular nano method to copy (Alt+Shift+A to mark, arrow keys to select, Alt+Shift+6 to copy) and then paste using Ctrl+Shift+V into a Windows app, still no luck.
What am I missing?
davemackey
  • 214
The usual way is selecting the text with the mouse and right click for copy.
You can also use clip.exe to copy all the content of a linux file to Windows Clipboard.
cat ~/.ssh/id_rsa.pub | clip.exe
onoma
  • 346
Select the text with the left mouse button and press once on the right mouse button to copy on the Windows clipboard.
Now you can paste the copied text in WSL with another right button click, or paste in Windows with CTRL-V.
So when you want to copy/paste in WSL, you press the buttons left (select the text with the mouse), right, right.
Edit: Part beneath was a comment:
In Nano first change the layout to soft wrapping (soft: don't insert real new lines) . Nano help explains: Meta-key sequences are notated with 'M-' and can be entered using either the Alt, Cmd, or Esc key, depending on your keyboard setup. and M-$ Soft wrapping of overlong lines enable/disable. With my keyboard layout ($ above the 4) this results in ALT-SHIFT-4. Now the long lines are wrapped and visible in the screen.
Walter A
  • 141
The Windows keystroke for Paste is Ctrl-V.
K7AAY
  • 17,705
I think maybe you can just try using ssh or sftp protocol to transfer the file. An easy way to do it sftp username@ipaddress. When i face such issues where i cannot copy from one sys to another. It comes in handy a lot.
