Is it possible to install MySQL Server 5.7 on Ubuntu 19.10? If yes, how?
Kulfy
  • 18,154
MySQL server 5.7 isn't available in the repositories of Eoan Ermine (19.10) but is available in Bionic Beaver (18.04) from Ubuntu's official repostories as well as MySQL's. You can install MySQL Server 5.7 on Eoan using Bionic's repository.
  1. To use MySQL's repository for Ubuntu 18.04
    • First of all create a new text file with sudo privileges:
      sudo nano /etc/apt/sources.list.d/mysql.list
    • Add these lines:
      deb http://repo.mysql.com/apt/ubuntu/ bionic mysql-apt-config
      deb http://repo.mysql.com/apt/ubuntu/ bionic mysql-5.7
      deb http://repo.mysql.com/apt/ubuntu/ bionic mysql-tools
      #deb http://repo.mysql.com/apt/ubuntu/ bionic mysql-tools-preview
      deb-src http://repo.mysql.com/apt/ubuntu/ bionic mysql-5.7
      You can comment/uncomment the repository according to the packages required. Save and exit using Ctrl+X followed by Y. Then run
      sudo apt update
    • You'll get an error, like
      Err:1 http://repo.mysql.com/apt/ubuntu bionic InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY <some key value>
    • Add this key using
      sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys <key value>
    • Update and check which version of MySQL 5.7 is currently available
      sudo apt update
      apt-cache policy mysql-server
      At the time of writing this answer, 5.7.29-1ubuntu18.04 was available.
    • Install the required MySQL version.
      sudo apt install mysql-server=5.7.29-1ubuntu18.04
    Note: For some reasons in my installation APT wasn't installing mysql-client while installing MySQL Server 5.7 which is a dependency of MySQL Community Server which in turn is a dependency of MySQL Server due to which dependency issues occured. To get out of that I needed to install MySQL client using APT first
    sudo apt install mysql-client=5.7.29-1ubuntu18.04
  2. To install using Ubuntu's repositories, add Ubuntu 18.04's official repositories, update the cache and instal MySQL 5.7. Fo that run:
    echo "deb http://security.ubuntu.com/ubuntu/ bionic-security restricted main" | sudo tee /etc/apt/sources.list.d/bionic.list
    sudo apt update
    sudo apt install mysql-server=5.7.29-0ubuntu0.18.04.1
    I'd recommend to delete Bionic's repository after the installation since having repository information of other releases can sometime break the installation. To do that run
    sudo rm /etc/apt/sources.list.d/bionic.list
Kulfy
  • 18,154
Adding onto Kulfy's answer. If you want to prevent the package from being updated back to MySQL 8+, create a file named mysql at /etc/apt/preferences.d/.
In that file place the following contents
Package: mysql-server
Pin: version 5.7.29-1ubuntu18.04
Pin-Priority: 1001
Package: mysql-client
Pin-Priority: 1001
Package: mysql-community-server
Pin-Priority: 1001
Package: mysql-community-client
Pin-Priority: 1001
This will prevent apt upgrade from upgrading MySQL back to version 8.
NOTE: The version you use may be different, as of 2/12/2020 the version is 5.7.29-1ubuntu18.04. To get the version run apt list --installed | grep -E 'mysql-(client|server)'.
NSwanson7
  • 151
Extending on the answers of both Kulfy and NSwanson7, the installation can be fixed to version 5.7.*. No need to specify an exact version.
  1. Pin the version of mysql-client and mysql-server to 5.7*. For this create the file /etc/apt/preferences.d/mysql with content
    Pin: version 5.7*
    Pin-Priority: 1001
    Package: mysql-client Pin: version 5.7* Pin-Priority: 1001
  2. Add repositories from Ubuntu 18.04. For this create file /etc/apt/sources.list.d/mysql.list with content
  3. Update repos and install
    sudo apt update && sudo apt install mysql-client mysql-server
or use the below script:
echo "deb http://repo.mysql.com/apt/ubuntu/ bionic mysql-apt-config"  | sudo tee /etc/apt/sources.list.d/mysql.list
echo "deb http://repo.mysql.com/apt/ubuntu/ bionic mysql-5.7"  | sudo tee -a /etc/apt/sources.list.d/mysql.list
echo "deb http://repo.mysql.com/apt/ubuntu/ bionic mysql-tools"  | sudo tee -a /etc/apt/sources.list.d/mysql.list
echo "deb-src http://repo.mysql.com/apt/ubuntu/ bionic mysql-5.7"  | sudo tee -a /etc/apt/sources.list.d/mysql.list
echo "Package: mysql-server" | sudo tee /etc/apt/preferences.d/mysql echo "Pin: version 5.7" | sudo tee -a /etc/apt/preferences.d/mysql echo "Pin-Priority: 1001" | sudo tee -a /etc/apt/preferences.d/mysql echo "" | sudo tee -a /etc/apt/preferences.d/mysql echo "Package: mysql-client" | sudo tee -a /etc/apt/preferences.d/mysql echo "Pin: version 5.7" | sudo tee -a /etc/apt/preferences.d/mysql echo "Pin-Priority: 1001" | sudo tee -a /etc/apt/preferences.d/mysql
sudo apt update sudo apt -y install mysql-server mysql-client
hakai
  • 121
