I am relatively new to Ubuntu, and I am having trouble to install Dropbox under a completely fresh Ubuntu 18.04.
I had the same problem as described in this previous short question I can't install dropbox client: Cannont open libatomic.so.1 i.e. dropbox required the library libatomic1.
Unfortunately, the commmand:
sudo apt install libatomic1
only leads to the following error:
$sudo apt install libatomic1
Reading package lists... Done
Building dependency tree
libatomic1 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04.1 is to be installed
As suggested in the command, I ran:
sudo apt update
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://dl.google.com/linux/chrome/deb stable Release
Hit:3 http://ppa.launchpad.net/texworks/ppa/ubuntu bionic InRelease
Hit:5 http://archive.ubuntu.com/ubuntu bionic InRelease
Get:6 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:7 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Get:8 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
E: Release file for http://archive.ubuntu.com/ubuntu/dists/bionic-updates/InRelease is not valid yet (invalid for another 6h 42min 11s). Updates for this repository will not be applied.
E: Release file for http://archive.ubuntu.com/ubuntu/dists/bionic-backports/InRelease is not valid yet (invalid for another 6h 43min 16s). Updates for this repository will not be applied.
E: Release file for http://archive.ubuntu.com/ubuntu/dists/bionic-security/InRelease is not valid yet (invalid for another 6h 41min 22s). Updates for this repository will not be applied.
How do I fix this? Thank you in advance for your help.
