I'm trying to connect a bluetooth headset (Insignia NS-CAHBTEB01-B) to my computer, which is running an up-to-date install of Kubuntu 18.04. Everything seems to go smoothly at first -- I am able to pair the headset successfully using the "Bluetooth Devices" System Settings module GUI -- but the headset doesn't play audio output from the computer. Some things I have noticed:
  • I can tell the headset has paired successfully because I hear "Your device is connected" through the headphones. Also, pressing the play/pause button while watching a video in VLC will sometimes cause it to play or pause (not reliably), and using pacmd to change the active profile to headset_head_unit causes the headset to vibrate (see below).
  • The headset shows up in the "Audio Volume" widget in the system tray and in system settings. I can try to adjust the volume -- when I do this, I hear a faint hissing noise through the headphones. It persists for a second or two after I stop adjusting the volume slider, and then cuts off.
  • Running pacmd list-cards gives the following output (in part):
    index: 4
        driver: <module-bluez5-device.c>
        owner module: 28
        properties:
                device.description = "NS-CAHBTEB01"
                device.string = "E8:07:BF:02:3C:F1"
                device.api = "bluez"
                device.class = "sound"
                device.bus = "bluetooth"
                device.form_factor = "headset"
                bluez.path = "/org/bluez/hci0/dev_E8_07_BF_02_3C_F1"
                bluez.class = "0x240404"
                bluez.alias = "NS-CAHBTEB01"
                device.icon_name = "audio-headset-bluetooth"
                device.intended_roles = "phone"
        profiles:
                a2dp_sink: High Fidelity Playback (A2DP Sink) (priority 40, available: unknown)
                headset_head_unit: Headset Head Unit (HSP/HFP) (priority 30, available: unknown)
                off: Off (priority 0, available: yes)
        active profile: <a2dp_sink>
        sinks:
                bluez_sink.E8_07_BF_02_3C_F1.a2dp_sink/#6: NS-CAHBTEB01
        sources:
                bluez_sink.E8_07_BF_02_3C_F1.a2dp_sink.monitor/#9: Monitor of NS-CAHBTEB01
        ports:
                headset-output: Headset (priority 0, latency offset 0 usec, available: unknown)
                        properties:
                headset-input: Headset (priority 0, latency offset 0 usec, available: unknown)
                        properties:
I can then run pacmd set-card-profile 4 headset_head_unit and pacmd set-card-profile 4 a2dp_sink to switch back and forth between the headset_head_unit and a2dp_sink profiles, which seems to be successful (changes the active_profile line above and causes the headset to buzz when I switch to headset_head_unit), but doesn't get me sound out of the headphones.
Solutions I have ruled out:
The only evidence I've found of something going wrong, other than the lack of audio playing through the headphones, is the fact that running pactl load-module module-bluetooth-discover gives the error Failure: Module initialization failed. I'm not sure what's causing this.
How can I get my headset to play audio?
