My Kubuntu 18.04 (LTS) takes about 3 minutes to boot. It is about 6 months old atm.
Following are the relevant details :
uname -a
Linux konsole 5.0.0-31-generic #33~18.04.1-Ubuntu SMP Tue Oct 1 10:20:39 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
systemd-analyze
Startup finished in 5.754s (kernel) + 46.078s (userspace) = 51.833s
graphical.target reached after 46.059s in userspace
(Selecting the first few)
systemd-analyze blame
         15.969s systemd-journal-flush.service
         13.596s NetworkManager-wait-online.service
         13.000s networkd-dispatcher.service
         12.798s dev-sda1.device
          8.445s gpu-manager.service
          7.320s udisks2.service
          6.598s ssh.service
          5.433s NetworkManager.service
          5.351s ModemManager.service
          4.917s systemd-udevd.service
          4.525s vboxdrv.service
          4.520s apparmor.service
          4.164s grub-common.service
          3.576s accounts-daemon.service
          3.110s thermald.service
          3.109s bluetooth.service
          3.107s lm-sensors.service
          2.491s wpa_supplicant.service
          2.335s systemd-tmpfiles-setup.service
          1.901s systemd-rfkill.service
          1.862s systemd-logind.service
          1.709s systemd-fsck@dev-disk-by\x2duuid-199d5cb3\x2d2d16\x2d4f3f\x2d8af8\x2d99c53ad33b9f.service
          1.634s avahi-daemon.service
          1.441s systemd-backlight@backlight:intel_backlight.service
          1.286s packagekit.service
          1.271s systemd-tmpfiles-setup-dev.service
          1.168s systemd-modules-load.service
          1.157s binfmt-support.service
          1.045s keyboard-setup.service
The time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @30.321s
└─multi-user.target @30.321s
  └─networkd-dispatcher.service @20.286s +10.034s
    └─basic.target @17.615s
      └─sockets.target @17.615s
        └─avahi-daemon.socket @17.615s
          └─sysinit.target @17.523s
            └─apparmor.service @14.592s +2.930s
              └─local-fs.target @14.590s
                └─home.mount @14.347s +242ms
                  └─systemd-fsck@dev-disk-by\x2duuid-199d5cb3\x2d2d16\x2d4f3f\x2d8af8\x2d99c53ad33b9f.service @12.804s +1.478s
                    └─dev-disk-by\x2duuid-199d5cb3\x2d2d16\x2d4f3f\x2d8af8\x2d99c53ad33b9f.device @12.803s
A few services can be disabled to reduce the boot-up time with no effect on the desktop environment functionality in most cases:
Firstly:
POSTFIX appears in your post. If your machine is not a mail server and you do not use POSTFIX you can disable the postfix.service by running the following command in the terminal:
sudo systemctl disable postfix.service
Or you can uninstall POSTFIX all together by running the following command in the terminal:
sudo apt remove postfix
Secondly:
NetworkManager-wait-online.service can be disabled by running the following command in the terminal:
sudo systemctl disable NetworkManager-wait-online.service
Please refer to this answer for more explanation.
Thirdly:
Two services that rely on the functionality of NetworkManager-wait-online.service are networkd-dispatcher.service and systemd-networkd.service. These can be disabled as well by running the following commends in the terminal:
sudo systemctl disable networkd-dispatcher.service
And:
sudo systemctl disable systemd-networkd.service
These two services are used strictly for systemd's connectivity purposes and will not affect the connectivity of the desktop environment after login.
Raffa
  • 34,963
