Ubuntu 20.04 webserver Platforms : Webmin/Virtualmin Hardware: i5-4570 + 8gb ram and 1 SSD
I had installed OpenMediaVault at some point on server and i purged it and removed ssd with the openmedia vault. I think boot time is affected by this. Here are some commands from logs:
systemd-analyze time
Results:
Startup finished in 5.827s (firmware) + 2.794s (loader) + 3.302s (kernel) + 1min 40.095s (userspace) = 1min 52.019s graphical.target reached after 1min 39.551s in userspace
sudo nano /etc/fstab
# /etc/fstab: static file system information.# # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # # / was on /dev/ubuntu-vg/ubuntu-lv during curtin installation /dev/disk/by-id/dm-uuid-LVM-CJuruIAJZ5Q4ZkBVfCqAwkGKk2ZIm32RCgDjKUKm1sYS3TRzwt OQyPyeFc3HBDR0 / ext4 defaults 0 1 # /boot was on /dev/sda2 during curtin installation /dev/disk/by-uuid/205cf80c-fb9e-473a-82d6-25329a34e693 /boot ext4 defaults 0 1 # /boot/efi was on /dev/sda1 during curtin installation /dev/disk/by-uuid/26BE-A316 /boot/efi vfat defaults 0 1 # /home was on /dev/ubuntu-vg/lv-0 during curtin installation /dev/disk/by-id/dm-uuid-LVM-CJuruIAJZ5Q4ZkBVfCqAwkGKk2ZIm32R3790Nfb6JxUmVgpjlx JwhtuwqXnJ9vDS /home ext4 usrquota,grpquota,quota,rw,relatime 0 1 /swap.img none swap sw 0 0 LABEL=myvault /home/myvault ext4 defaults 0 0 /dev/sda5 /free ext3 defaults 0 0
sudo blkid -o listdevice
root@ns2:/# sudo blkid -o listdevice fs_type label mount point UUID -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- /dev/sda1 vfat /boot/efi 26BE-A316 /dev/sda2 ext4 /boot 205cf80c-fb9e-473a-82d6-25329a34e693 /dev/sda3 LVM2_member (in use) xSawZN-We9k-jleS-QCAB-nRRB-sAKr-8a3Qnd /dev/sda5 ext3 /free 53e83fc3-d397-4021-a00e-a4bc4360ba45 /dev/mapper/ubuntu--vg-ubuntu--lv ext4 / cb9e6bda-3cf2-426c-bb17-e2978292f8aa /dev/mapper/ubuntu--vg-lv--0 ext4 /home fd9bce36-259b-4012-960c-d352934d2af1 /dev/loop0 squashfs /snap/core20/1879 /dev/loop1 squashfs /snap/lxd/23991 /dev/loop2 squashfs /snap/core20/1891 /dev/loop3 squashfs /snap/snapd/18933 /dev/loop4 squashfs /snap/lxd/24061 /dev/loop5
systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.The time the unit took to start is printed after the "+" character. graphical.target @1min 39.551s └─multi-user.target @1min 39.551s └─postfix.service @1min 39.548s +1ms └─postfix@-.service @1min 37.427s +2.120s └─network-online.target @1min 37.407s └─systemd-networkd-wait-online.service @1min 32.257s +5.148s └─systemd-networkd.service @1min 32.196s +59ms └─network-pre.target @1min 32.195s └─firewalld.service @1min 31.788s +406ms └─polkit.service @1min 31.310s +475ms └─basic.target @1min 31.281s └─sockets.target @1min 31.281s └─uuidd.socket @1min 31.281s └─sysinit.target @1min 31.273s └─cloud-init-local.service @1min 30.522s +751ms └─systemd-remount-fs.service @454ms +11ms └─systemd-journald.socket @439ms └─system.slice @435ms └─-.slice @435ms Weird jump from remount fs service from 454 ms to cloud-init-local.service at 1min30sec
