28
I am getting the following error message as a list of 4 or 5 lines with differing numbers at the beginning of each line during boot for a long while:
ima: error communicating to tpm chip
I am using Ubuntu 19.04 (though this error was existing for a while at the older versions) and my computer is a Toshiba Z930.
alpakyuz
  • 437
7 Answers7
14
It is simple: just enable TPM from the BIOS setup.
To change the BIOS settings you can hit F2 during boot before Ubuntu starts. Please be sure not to change anything else if your computer is working properly.
alpakyuz
  • 437
If you couldn't find TPM, it appears as Intel Platform Trust Technology in the Security section of the BIOS. I had to disable that setting in order to get rid of that error.
dilver
  • 91
TPM may not be named clearly in the BIOS settings. In my BIOS, it definitely was not. The setting was initially disabled and required setting a password before it could be enabled. There was a sub-setting to allow the Operating System to make changes.
If you don't have a configuration password, check for security settings that are disabled and can not be changed. Try setting a password and enable the configuration.
BillThor
  • 4,698
I had to boot into my motherboard Bios Setup by pressing esc to get into the Startup Menu then F10 to get into Computer setup or cut it short by pressing F10 before the OS boots up . After getting into the Bios Setup -and that primarily applies to my bios UI version and other similar ones- just
  1. Move to Security tab
  2. Navigate down to select the System Security menu option
  3. Another popup menu with the Embedded Security Device option would be most probably disabled.
  4. Escape back out of the menu then navigate up to Setup Password
  5. Set up a new password
  6. sway back to the Embedded Security Device to get it enabled.
  • Also make sure to enable all the options -or at least the one you want to enable- at the Device Security option .
Just as a side note, this error is somehow interconnected with Ata comreset failed (errno=-16). So if by any chance someone googled this otherwise different error message and landed on this page, then then this solution might resolve the issue at this particular case .
kqvanity
  • 135
On my Lenovo Thinkpad T420,
  1. Hit the ThinkVantage button during bootup to enter BIOS.
  2. Hit F1 to enter BIOS.
  3. Go to Security
  4. Hit enter on Security Chip to drilldown.
  5. Set Security Chip to Active (Inactive was existing).
  6. Restart with "Exit Saving Changes".
This messages showed up after I did a Ubuntu 2x.xx update.
For my NUC it showed up under "Devices and Peripherals > Onboard Devices > Legacy Device Configuration > Trusted Platform Module"
Peter
  • 391
Not always the BIOS gives you the options for TPM for granted. So on my Elitebook 8570P it is simply NOT possible to alter the TPM settings in any way. Of course you do not want the messages at the startup prompt during and in between the boot-splash. So you can do the following:
  1. In a terminal run:
    sudo nano /etc/default/grub
  2. Navigate with the arrow keys on your keyboard to the place where it says:
    quiet splash
    and change it to:
    quiet loglevel=0 splash
  3. Save the file and run:
    sudo update-grub
  4. Reboot and you will see that there are no messages anymore of the TPM error.
This tip is mostly for people who do not want to mess in the BIOS. Tested this on a HP Elitebook 8570P with Jammy Jellyfish fresh installed.
