I installed yesterday Ubuntu 18.04 in dual boot on a computer usually used with Windows 7.
Everything went fine, except that I am unable to connect to my WiFi network. The weirdest thing being that my Network card seems to work perfectly: Ubuntu's Network Manager detects all the surrounding WiFi networks, except for mine, which is called "WiFi-2.4-68B7".
I already tried different solutions, none worked:
  1. I configured "WiFi-2.4-68B7" in the "known networks" and tried to access it through the "Connect to hidden network tool".
  2. I checked whether Ubuntu was detecting my Network chipset correctly, which appears to be the case:
dd@dd:~$ sudo lspci
Network controller: Broadcom Inc. and subsidiaries BCM4313 802.11bgn Wireless Network Adapter (rev 01)
  1. I tried reinstalling the Broadcom driver for my BCM4313
dd@dd:~$ sudo apt-get --reinstall install bcmwl-kernel-source
  1. I also tried the solution proposed here, but with no result.
I am out of ideas to solve the problem. It should be noted I can connect just fine to my WiFi network when I boot from Windows 7, the problem is thus not from the hardware.
Does anyone have an idea? Thank you!
Damien
  • 171
Changing Channel fixed my problem. To see which channel is good for you, run this command on ubuntu.
sudo iwlist wlan0 scan | grep Frequency | sort | uniq -c | sort -n
if you encounter an error say, wlan0 doesn't support scanning then, run this command
ifconfig
make sure you have installed net-tools if you can't run ifconfig
sudo apt install net-tools
look for output - two words wl mine was wlp2s0, so the command would be
sudo iwlist wlp2s0 scan | grep Frequency | sort | uniq -c | sort -n
The “sort -n” command will rank the channels in order of fastest to slowest
In the router, you change your channel.
then restart your network-manager
sudo service network-manager restart
Alternatively, you can also check if wifi is blocked - https://unix.stackexchange.com/a/309753/330133
Thanks to Jeremy31, it appeared that the problem came from the fact that my WiFi network was set to channel 13. After switching it back to a channel <11, I can now see the network and connect to it without problem.
Damien
  • 171
Perhaps its an issue over the type of Network? Are you connecting to a 5gHz or a 2.4gHz network? I know that I sometimes have issues with the 5gHz networks being picked up. I had to you Wine to set up my drivers. It sounds like you are technically more adept than I am so I won't bother giving you instructions on how I did that...unless you arent sure how to use wine. Then I would be happy to help/ Also check to see that windows is disconection from your network so the router knows to allow you to connect. You wouldnt be using static IP would you? if so that could be the case...
