This is my First Question in the form.
I have an hp-ac122tu laptop with realtek NIC.
I can connect to all Wi-Fi routers and my Android hot-spot without any problem( Except Network manager won't refresh until restart). But this particular Wi-Fi modem is not being detected by Ubuntu and Other Linux distro while my WIndows 10 and all other devices can connect to it hassle free.
Now How do I fix it? Any helping hand is appreciated.
Right now I'm using Wi-Fi by tethering my Android device.
~$ lspci -knn | grep Net -A2
0d:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
    Subsystem: Hewlett-Packard Company RTL8723BE PCIe Wireless Network Adapter [103c:804c]
    Kernel driver in use: rtl8723be
    Kernel modules: rtl8723be
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
VOiD
  • 41
Since not being able to get a proper solution from here I went on and took the risk of downloading a driver from gitub and manually installing my realtek driver.
type this in your terminal window
$ iwconfig
and found out my wifi's name. wlp13s0
https://github.com/lwfinger/rtlwifi_new/tree/rock.new_btcoex
went to this link and downloaded the zip file (clone). put it in the desktop and change directory using commands
$ cd Desktop
and extracted the file on desktop
$ cd rtlwifi_new-rock.new_btcoex
$ make && sudo make install && sudo modprobe -rv rtl8723be && sudo modprobe -v rtl8723be ant_sel=2 && sudo ip link set wlp13s0 up
THe last command is supposed to turn n wifi so just in case it doesn't work , manually turn on the Wi-Fi
and
$ sudo iw dev wlp13s0 scan
and THere my Wi-Fi hotspot name was listed.
$ echo "options rtl8723be ant_sel=2" | sudo tee /etc/modprobe.d /50-rtl8723be.conf
to save the current configurations into the file.
Restarted my system. and Wi-Fi is normal and working all well.
another way is to change the tx power which is risky so I skipped.
In case anyone have the same problem with realtek linux drivers, follow these steps.
Note: For installing it in kali linux you will need to have latest kali release and kernel.
VOiD
  • 41
