I'm on Ubuntu 18.04, Gnome 3.28.2 with no dual boot and no external USB devices. Once in a while I get a black terminal screen with several errors like this:
[ 5307.281824] systend-journald(539]: Failed to write entry (24 items, 581 bytes), ignoring: Read-only file system
When I get this black screen the computer doesn't respond anymore and I have to reboot by pressing the power button.
Hardware and OS info:
(base) x@x:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 8074028 0 8074028 0% /dev
tmpfs 1621272 2176 1619096 1% /run
/dev/mapper/ubuntu--vg-root 113125620 97117896 10218236 91% /
tmpfs 8106348 126836 7979512 2% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 8106348 0 8106348 0% /sys/fs/cgroup
/dev/loop3 1024 1024 0 100% /snap/gnome-logs/61
/dev/loop2 69248 69248 0 100% /snap/sublime-text/67
/dev/loop1 4224 4224 0 100% /snap/gnome-calculator/406
/dev/sda1 720368 150420 517556 23% /boot
/dev/loop4 90880 90880 0 100% /snap/core/7396
/dev/loop5 141696 141696 0 100% /snap/thunderbird/29
/dev/loop7 224256 224256 0 100% /snap/gimp/165
/dev/loop8 88448 88448 0 100% /snap/ubuntu-mate-welcome/335
/dev/loop11 19200 19200 0 100% /snap/communitheme/1593
/dev/loop10 58368 58368 0 100% /snap/powershell/36
/dev/loop12 268544 268544 0 100% /snap/gnss-sdr-next/285
/dev/loop14 207232 207232 0 100% /snap/vlc/770
/dev/loop19 15104 15104 0 100% /snap/gnome-characters/317
/dev/loop16 99840 99840 0 100% /snap/ubuntu-mate-welcome/296
/dev/loop15 48896 48896 0 100% /snap/riseup-vpn/152
/dev/loop20 15104 15104 0 100% /snap/gnome-characters/296
/dev/loop21 153216 153216 0 100% /snap/slack/16
/dev/loop22 153600 153600 0 100% /snap/gnome-3-28-1804/71
/dev/loop24 1280 1280 0 100% /snap/tinc-vpn/2
/dev/loop26 150144 150144 0 100% /snap/slack/17
/dev/loop27 43904 43904 0 100% /snap/gtk-common-themes/1313
/dev/loop30 153600 153600 0 100% /snap/gnome-3-28-1804/67
/dev/loop31 207744 207744 0 100% /snap/vlc/1049
/dev/loop33 58368 58368 0 100% /snap/powershell/34
/dev/loop34 16384 16384 0 100% /snap/communitheme/1768
/dev/loop35 88832 88832 0 100% /snap/ubuntu-mate-welcome/319
/dev/loop36 144128 144128 0 100% /snap/gnome-3-26-1604/90
/dev/loop37 127360 127360 0 100% /snap/electron-mail/13
/dev/loop38 36224 36224 0 100% /snap/gtk-common-themes/1198
/dev/loop39 153344 153344 0 100% /snap/chromium/849
/dev/loop40 77568 77568 0 100% /snap/cubicsdr-casept/4
/dev/loop41 3840 3840 0 100% /snap/gnome-system-monitor/95
/dev/loop42 19072 19072 0 100% /snap/communitheme/1524
/dev/loop43 55808 55808 0 100% /snap/core18/1098
/dev/loop45 327936 327936 0 100% /snap/pycharm-community/147
/dev/loop46 69248 69248 0 100% /snap/sublime-text/69
/dev/loop47 3840 3840 0 100% /snap/gnome-system-monitor/100
/dev/loop48 224384 224384 0 100% /snap/gimp/189
tmpfs 1621268 28 1621240 1% /run/user/121
tmpfs 1621268 76 1621192 1% /run/user/1000
/dev/loop49 144128 144128 0 100% /snap/gnome-3-26-1604/92
/dev/loop23 97024 97024 0 100% /snap/telegram-desktop/908
/dev/loop25 91264 91264 0 100% /snap/core/7713
/dev/loop6 1024 1024 0 100% /snap/gnome-logs/73
/dev/loop50 4352 4352 0 100% /snap/gnome-calculator/501
/dev/loop13 97152 97152 0 100% /snap/telegram-desktop/936
/dev/loop17 268544 268544 0 100% /snap/gnss-sdr-next/292
/dev/loop0 159616 159616 0 100% /snap/chromium/853
/dev/loop18 327936 327936 0 100% /snap/pycharm-community/150
/dev/loop28 55808 55808 0 100% /snap/core18/1144
(base) x@x:~$
Hardware list:
root@x:/home/x# lshw
x
description: Notebook
product: 80RU (LENOVO_MT_80RU_BU_idea_FM_Lenovo ideapad 700-15ISK)
vendor: LENOVO
version: Lenovo ideapad 700-15ISK
serial: R90K3F7XR9N0B631000C
width: 64 bits
capabilities: smbios-2.8 dmi-2.8 smp vsyscall32
configuration: administrator_password=enabled boot=normal chassis=notebook family=IDEAPAD frontpanel_password=disabled keyboard_password=disabled power-on_password=disabled sku=LENOVO_MT_80RU_BU_idea_FM_Lenovo ideapad 700-15ISK uuid=800CF8AE-A5E6-E511-88B2-08D40CB5171E
*-core
description: Motherboard
product: Lenovo ideapad 700-15ISK
vendor: LENOVO
physical id: 0
version: SDK0J40709 WIN
serial: R90K3F7X
slot: Part Component
*-cache:0
description: L1 cache
physical id: 2
slot: L1 Cache
capacity: 128KiB
capabilities: synchronous internal write-back data
configuration: level=1
*-cache:1
physical id: 3
slot: L1 Cache
capacity: 128KiB
capabilities: synchronous internal write-back instruction
*-cache:2
description: L2 cache
physical id: 4
slot: L2 Cache
capacity: 1MiB
capabilities: synchronous internal write-back unified
configuration: level=2
*-cache:3
description: L3 cache
physical id: 5
slot: L3 Cache
capacity: 6MiB
configuration: level=3
*-cpu
description: CPU
product: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
vendor: Intel Corp.
physical id: 6
bus info: cpu@0
version: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
serial: To Be Filled By O.E.M.
slot: U3E1
capacity: 3500MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d cpufreq
configuration: cores=4 enabledcores=4 threads=8
*-memory
description: System Memory
physical id: 7
slot: System board or motherboard
*-bank:0
description: SODIMM DDR4 Synchronous 2133 MHz (0.5 ns)
product: CT8G4SFD8213.C16FBD1
vendor: Conexant (Rockwell)
physical id: 0
serial: 16141922
slot: ChannelA-DIMM0
width: 64 bits
clock: 2133MHz (0.5ns)
*-bank:1
description: Project-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME <EMAIL@ADDRESS>PO-Revision-Date: 2012-02-05 00:26+0000Last-Translator: Andi Chandler <Unknown>Language-Team: English (United Kingdom) <en_GB@li.org>MIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2018-07-12 13:19+0000X-Generator: Launchpad (build 18719)Project-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME <EMAIL@ADDRESS>PO-Revision-Date: 2012-02-05 00:26+0000Last-Translator: Andi Chandler <Unknown>Language-Team: English (United Kingdom) <en_GB@li.org>MIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2018-07-12 13:19+0000X-Generator: Launchpad (build 18719) [empty]
physical id: 1
slot: ChannelA-DIMM1
*-bank:2
physical id: 2
serial: 16270421
slot: ChannelB-DIMM0
width: 64 bits
*-bank:3
physical id: 3
slot: ChannelB-DIMM1
*-firmware
description: BIOS
vendor: LENOVO
physical id: d
version: E5CN21WW
date: 12/28/2015
capacity: 8128KiB
capabilities: pci upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer int10video pc98 acpi usb ls120boot zipboot biosbootspecification netboot
*-pci
description: Host bridge
product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 07
width: 32 bits
clock: 33MHz
configuration: driver=skl_uncore
resources: irq:0
*-pci:0
description: PCI bridge
product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16)
physical id: 1
bus info: pci@0000:00:01.0
version: 07
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:120 ioport:d000(size=4096) memory:d1000000-d1ffffff ioport:a0000000(size=301989888)
*-display
description: 3D controller
product: GM107M [GeForce GTX 950M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=nouveau latency=0
resources: irq:126 memory:d1000000-d1ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:d000(size=128)
*-display
description: VGA compatible controller
product: HD Graphics 530
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:127 memory:d0000000-d0ffffff memory:c0000000-cfffffff ioport:e000(size=64) memory:c0000-dffff
*-usb
description: USB controller
product: 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 31
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:123 memory:d2200000-d220ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 4.15.0-60-generic xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 4.15
capabilities: usb-2.00
configuration: driver=hub slots=16 speed=480Mbit/s
*-usb:0
description: Keyboard
product: USB Receiver
vendor: Logitech
physical id: 1
bus info: usb@1:1
version: 29.01
configuration: driver=usbhid maxpower=98mA speed=12Mbit/s
*-usb:1
description: Video
product: Lenovo EasyCamera
vendor: Bison
physical id: 5
bus info: usb@1:5
version: 42.09
serial: 200901010001
configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
*-usb:2
description: Bluetooth wireless interface
vendor: Intel Corp.
physical id: 7
bus info: usb@1:7
version: 0.01
capabilities: bluetooth usb-2.00
configuration: driver=btusb maxpower=100mA speed=12Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 4.15
capabilities: usb-3.00
configuration: driver=hub slots=8 speed=5000Mbit/s
*-generic:0
description: Signal processing controller
product: 100 Series/C230 Series Chipset Family Thermal Subsystem
physical id: 14.2
bus info: pci@0000:00:14.2
version: 31
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=intel_pch_thermal latency=0
resources: irq:18 memory:d222a000-d222afff
*-communication
description: Communication controller
product: 100 Series/C230 Series Chipset Family MEI Controller #1
physical id: 16
bus info: pci@0000:00:16.0
version: 31
width: 64 bits
clock: 33MHz
configuration: driver=mei_me latency=0
resources: irq:128 memory:d222c000-d222cfff
*-storage
description: SATA controller
product: HM170/QM170 Chipset SATA Controller [AHCI Mode]
physical id: 17
bus info: pci@0000:00:17.0
version: 31
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:124 memory:d2228000-d2229fff memory:d2230000-d22300ff ioport:e080(size=8) ioport:e088(size=4) ioport:e060(size=32) memory:d222e000-d222e7ff
*-pci:1
product: 100 Series/C230 Series Chipset Family PCI Express Root Port #5
physical id: 1c
bus info: pci@0000:00:1c.0
version: f1
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
resources: irq:121 memory:d2100000-d21fffff
*-network
description: Wireless interface
product: Dual Band Wireless-AC 3165 Plus Bluetooth
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 99
serial: 08:d4:0c:b5:17:1a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=4.15.0-60-generic firmware=29.1044073957.0 ip=192.168.1.69 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:129 memory:d2100000-d2101fff
*-pci:2
product: 100 Series/C230 Series Chipset Family PCI Express Root Port #6
physical id: 1c.5
bus info: pci@0000:00:1c.5
version: f1
width: 32 bits
clock: 33MHz
resources: irq:122 ioport:c000(size=4096) memory:d2000000-d20fffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 15
serial: 54:ee:75:94:08:75
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:17 ioport:c000(size=256) memory:d2004000-d2004fff memory:d2000000-d2003fff
*-generic:1
product: 100 Series/C230 Series Chipset Family Serial IO UART #0
physical id: 1e
bus info: pci@0000:00:1e.0
version: 31
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=intel-lpss latency=0
resources: irq:20 memory:d222d000-d222dfff
*-isa
description: ISA bridge
product: HM170 Chipset LPC/eSPI Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 31
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
configuration: latency=0
*-memory UNCLAIMED
description: Memory controller
product: 100 Series/C230 Series Chipset Family Power Management Controller
physical id: 1f.2
bus info: pci@0000:00:1f.2
version: 31
width: 32 bits
clock: 33MHz (30.3ns)
capabilities: bus_master
resources: memory:d2224000-d2227fff
*-multimedia
description: Audio device
product: 100 Series/C230 Series Chipset Family HD Audio Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 31
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=64
resources: irq:130 memory:d2220000-d2223fff memory:d2210000-d221ffff
*-serial UNCLAIMED
description: SMBus
product: 100 Series/C230 Series Chipset Family SMBus
physical id: 1f.4
bus info: pci@0000:00:1f.4
version: 31
width: 64 bits
clock: 33MHz
resources: memory:d222f000-d222f0ff ioport:efa0(size=32)
*-scsi:0
physical id: 0
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: ADATA SP550NS38
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 4B
serial: 2G4220000183
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 logicalsectorsize=512 sectorsize=512 signature=cb312d6a
*-volume:0
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
logical name: /boot
version: 1.0
serial: 6480205e-88e0-4b20-b930-38dee5b56148
capacity: 731MiB
capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2018-11-11 23:13:29 filesystem=ext4 lastmountpoint=/boot modified=2019-09-08 17:24:42 mount.fstype=ext4 mount.options=rw,relatime,data=ordered mounted=2019-09-08 17:24:42 state=mounted
*-volume:1
description: Extended partition
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
capacity: 111GiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume
description: Linux filesystem partition
physical id: 5
logical name: /dev/sda5
serial: 775a1793-1ea1-4fe2-bcd9-4880a3924ee0
capacity: 111GiB
width: 512 bits
capabilities: encrypted luks initialized
configuration: bits=512 cipher=aes filesystem=luks hash=sha256 mode=xts-plain64 version=1
*-scsi:1
physical id: 1
logical name: scsi2
*-disk
product: WDC WD10SPCX-24H
vendor: Western Digital
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/sdb
version: 1A02
serial: WD-WXA1AB57JSDL
configuration: ansiversion=5 logicalsectorsize=512 sectorsize=4096 signature=30d5ab25
*-volume
vendor: Linux
physical id: 1
bus info: scsi@2:0.0.0,1
logical name: /dev/sdb1
version: 1.0
serial: 0210a406-4dce-4a43-ac18-82f1a30c8c2c
capacity: 931GiB
capabilities: primary journaled extended_attributes large_files huge_files dir_nlink 64bit extents ext4 ext2 initialized
configuration: created=2018-11-09 17:40:00 filesystem=ext4 label=1TB lastmountpoint=/media/x/1TB modified=2019-09-06 11:31:08 mounted=2019-09-06 11:31:04 state=clean
*-battery
product: Smart Battery
vendor: Intel Corp.
physical id: 1
version: 2008
serial: 1.0
slot: Rear
I ran a quick smart test smartctl -l selftest /dev/sda which gives:
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.15.0-60-generic] (local build)
=== START OF READ SMART DATA SECTION ===
Warning! SMART Self-Test Log Structure error: invalid SMART checksum.
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 90 -
# 2 Short offline Completed without error 00% 90 -
# 3 Short offline Completed without error 00% 90 -
# 4 Offline Completed without error 00% 90 -
# 5 Short offline Self-test routine in progress 90% 102 -
# 6 Short offline Completed without error 00% 51 -
