I have a Dell Edge 5000 gateway that has Ubuntu 18.04 installed on it. It runs fine, but it fails to boot every 15 to 20 boots. There are several error messages that are displayed that all seem related.
systemd-journald[250]: Failed to rotate /var/log/journal/XXXXXXXXXXXXXXXXXXXXXXX.journal: Read-only file system
systemd-journald[250]: Failed to write entry (X items, XXX bytes), ignoring: Input/Output error
blk_update_request: I/O error, dev sda, sector XXXXXXXX op 0x0: (READ) flags 0x0 phys_seg 1 prio class 0
It will display a combination of these messages and pop up with a few more lines every few seconds. This will keep up indefinitely until I cycle power.
I have checked the disk as many ways as I can think of. I have used the BIOS scan tool (long and short scans), fsck, smartctl (including long scan), and badblocks. Everything passes and shows no errors.
Please let me know if you have any ideas. I'm convinced that something else is causing the drive to mount read only. I'd rather not specify in fstab to ignore filesystem errors.
I appreciate the help.
EDIT:
I learned more today.
If run "fsck -Cf /dev/sda2" to force a scan of the drive, everything checks out just fine.
However, if I run "fsck -Cfc /dev/sda2", to force the badblocks scan, I have have problems. It does report any bad blocks, but it will fail when checking inodes. It will say that every single inode is bad despite having passed in the previous command. It gets even more interesting if I just reboot. The reboot will cause the BIOS to not recognize the hardware. If I power down, the next startup will fail. The next power cycle will boot fine.
I also caught where the failure was occurring on boot today, but I dont know how helpful it is. I have not had a chance to fully exhaust google yet.
EXT4-fs error (device sda2): __ext4_find_entry:1532: inode #1638541: comm gdm3:reading directory iblock 0
It just went into the same journal errors after this. I'll keep this updated as I find out more. Thanks for the help so far.
