This kind of problems is probably as old as bluetooth headsets started becoming more popular... This time I can connect the headset, sound settings show both left and right as available and at full volume, but the sound only comes from the right earphone when A2DP is enabled. If I switch to HSP/HFP, sound comes from the left as expected.
UPD: I followed all the steps from Ubuntu 18.04: Audio doesn't work unless I switch between outputs. The difference between my problem and his is that I don't get the test sounds at all and all the other programs just output into the right earphone, but not left. In alsamixer nothing is muted.
UPD2: Here's the result of apt list --installed | grep -E "pulseaudio|pulseaudio-module-bluetooth|pavucontrol|bluez":
bluez-cups/disco,now 5.50-0ubuntu2 amd64 [installed]
bluez-obexd/disco,now 5.50-0ubuntu2 amd64 [installed,automatic]
bluez/disco,now 5.50-0ubuntu2 amd64 [installed]
gstreamer1.0-pulseaudio/disco,now 1.15.90-1ubuntu1 amd64 [installed]
pavucontrol/disco,now 3.0-4 amd64 [installed]
pulseaudio-dlna/disco,disco,now 0.5.3+git20170406-1 all [installed]
pulseaudio-module-bluetooth/disco,now 1:12.2-2ubuntu3 amd64 [installed]
pulseaudio-utils/disco,now 1:12.2-2ubuntu3 amd64 [installed,automatic]
pulseaudio/disco,now 1:12.2-2ubuntu3 amd64 [installed]
Worth noting that this issue happened after an update this week, here's the list of packages that were updated:
cups-bsd:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
cups-client:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
cups-common:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
cups-core-drivers:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
cups-daemon:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
cups-ipp-utils:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1))
cups-ppdc:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
cups-server-common:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
cups:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
libblockdev-crypto2:amd64 (2.20-7, 2.20-7ubuntu0.1)
libblockdev-fs2:amd64 (2.20-7, 2.20-7ubuntu0.1)
libblockdev-loop2:amd64 (2.20-7, 2.20-7ubuntu0.1)
libblockdev-part-err2:amd64 (2.20-7, 2.20-7ubuntu0.1)
libblockdev-part2:amd64 (2.20-7, 2.20-7ubuntu0.1)
libblockdev-swap2:amd64 (2.20-7, 2.20-7ubuntu0.1)
libblockdev-utils2:amd64 (2.20-7, 2.20-7ubuntu0.1)
libblockdev2:amd64 (2.20-7, 2.20-7ubuntu0.1)
libcups2:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
libcupsimage2:amd64 (2.2.10-4ubuntu2, 2.2.10-4ubuntu2.1)
libegl-mesa0:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libegl1-mesa:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libgbm1:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libgif7:amd64 (5.1.4-3, 5.1.4-3ubuntu0.1)
libgl1-mesa-dri:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libgl1-mesa-dri:i386 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libgl1-mesa-glx:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libgl1-mesa-glx:i386 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libglapi-mesa:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libglapi-mesa:i386 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libglx-mesa0:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libglx-mesa0:i386 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
libprocps7:amd64 (2:3.3.15-2ubuntu2, 2:3.3.15-2ubuntu2.1)
libxatracker2:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
mesa-va-drivers:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
mesa-vdpau-drivers:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
mesa-vulkan-drivers:amd64 (19.0.2-1ubuntu1.1, 19.0.8-0ubuntu0~19.04.1)
procps:amd64 (2:3.3.15-2ubuntu2, 2:3.3.15-2ubuntu2.1)
It doesn't look like there's anything bluetooth related, but maybe you'd know more.
