I'm having issues with the sound on my Dell Inspiron 3133 Chromebook that has transitioned to Lubuntu LTS 18.04.
I removed ChromeOS entirely and installed Lubuntu 18.04 using the following tutorial: https://youtu.be/AxsckwmRhfw
I followed every step in this tutorial, except in lieu of installing a full Ubuntu 18.04 LTS system, I installed Lubuntu.
When I run sudo lshw, I get this as my audio hardware description:
High Definition Audio Controller
vendor: Intel Corporation
physical id: 1b
bus info: pci@0000:00:1b.0
version: 35
width: 64 bits
clock: 33MHz
capabilities: pm msi cap_list
configuration: latency
resources: memory:d1314000-d1317fff
        *-pci:0
             description: PCI bridge
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
When I run lspci -v, I get this:
00:1b.0 Audio device: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller (rev 35)
    Subsystem: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller
    Flags: fast devsel
    Memory at d1314000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: access denied
    Kernel modules: snd_hda_intel
When I run sudo aplay -l, I get this:
aplay: device_list:270: no soundcards found...
Tried every step in this tutorial: Ubuntu 18.04 soundcard not detected
When I attempt this subtutorial of that tutorial - Sound card not detecting - I only found a compatible .tar.gz file, not a .deb file. I decompressed it into /usr/sbin (since alsa is there), kept it in its folder, and ran the Makefile within it.
All of these, to no effect.
Do I have any hope?
wxl
  • 1,026
