11
Sometimes I like to watch VLC media on my TV connected to the HDMI port on my laptop and I now have to:
  • Start VLC on the TV:
    • Positioned on the TV by CCSM.
    • The screen saver is being turned off by VLC.
  • Close the laptop
  • Turn off the monitor (If it's on)
because I like to sit in the dark while watching TV!
Has anyone solved the above already for themselves through a script?
The TV is always connected to HDMI and the monitor always to the VGA port if that makes things easier.
Fabby
  • 35,017
I've created a script that slowly dims two monitors after 5 minutes of keyboard or mouse inactivity while you watch a movie on a third monitor. When you move your mouse or use your keyboard the two dimmed monitors quickly brighten (but not suddenly to shock you).
Sample status screen
Before you think I watch too much TV note this is a laptop and the program has been running for many days and the laptop is suspended / resumed twice a day at least.
Setup Instructions
Save the script below to a filename in your path such as /usr/local/bin/movie.sh or /home/your_user_name/bin/movie.sh and then use:
chmod a+x /path/to/script/movie.sh
Xorg's package xprintidle is required to track how long your computer has been idle since a mouse movement or keyboard activity:
sudo apt install xprintidle
Then to launch the script use:
movie.sh
Note: When testing, change TIME_TO_FADE from 200000 to 10000 so you only have to wait 10 seconds instead of 200 seconds for fading to start.
The script
#!/bin/bash
PATH: ~/eyesome
DESC: Dim monitors 1 and 3 after 5 minutes of activity
DATE: June 27, 2019. Modified November 5, 2019.
PARM: Pass any parameter 1 to generate trace output
UPDT: 2019-07-05 Add dependancy message. Improve sleep calcualation.
2019-09-01 Display how long dimming lasted in hours, minutes, seconds
2019-09-07 Do not brighten if toggling play / pause of movie with
mouse click or Enter key. Log first wake and if a second wake appears
within 1 to 3 seconds then wake up. Otherwise forget first wake signal.
2019-11-05 Replace scrolling messages with Statistics display.
: <<'END' /* -----------------------------------------------------------------------------
CUSTOM NOTES
Put C-style free form notes here about disabling third party auto-brightness sunrise / sunset applications like nightlight, redshift, flux, eyesome, etc.
CONFIGURATION FILE LOCATION
$ ll /usr/local/bin/.eyesome-cfg -rw-r--r-- 1 root root 610 Jun 27 18:31 /usr/local/bin/.eyesome-cfg
CONFIGURATION FILE RECORD LAYOUT
$ cat /usr/local/bin/.eyesome-cfg https://www.timeanddate.com/sun/canada/edmonton|70.000000|120.000000|90.000000| 1.000000|TRUE| | | | |1|Disabled|Hardware|Alien 17" Builtin DIsplay| intel_backlight|eDP-1-1|3500.000000|1.000000|1.000000|1.000000|850.000000| 1.000000|0.780000|0.650000|3500|1.000000:1.000000:1.000000| | | | |2|Enabled| Software|Sony 50" TV|xrandr|HDMI-0|1.000000|1.000000|1.000000|1.000000|0.750000| 1.000000|0.950000|0.850000|1.00|1.000000:1.000000:1.000000| | | | |3|Disabled| Software|Toshibal 43" 4K TV|xrandr|DP-1-1|1.000000|1.000000|1.000000|1.000000| 0.650000|1.000000|0.880000|0.780000|1.00|1.000000:1.000000:1.000000| | | |
----------------------------------------------------------------------------- */ END
If sudo powers not needed, eg no 3rd party auto-brightening to disable,
then comment out the next four lines:
if [[ $(id -u) != 0 ]]; then # root powers needed to call this script echo >&2 "$0 must be called with sudo powers" exit 1 fi
command -v xprintidle >/dev/null 2>&1 || { echo >&2
"xprintidle package required but it is not installed. Aborting.";
exit 1; }
To echo debug/trace statements to screen, pass any parameter to script
Debug=0 [[ $# -gt 0 ]] && Debug=1
To get list of your monitors use: xrandr --verbose | grep " connected"
MON1="eDP-1-1" # eDP-1-1 = Laptop display MON2="" # HDMI-0 = Sony TV MON3="DP-1-1" # DP-1-1 = Toshiba TV
If you elect to turn backlight complete off and on you must use sudo
BACK="intel_backlight" # Setting to blank means no backlight to turn off/on
All seconds in millisconds, eg 1000 milliseconds = 1 second
TIME_TO_FADE=200000 # Keyboard/Mouse idle time before dim 300000 = 5 minutes TIME_TO_WAKE=2000 # 2 second time or less to trigger brightening FADE_SLEEP=.15 # When fading sleep seconds between monitor changes WAKE_SLEEP=.025 # When waking sleep seconds between monitor changes
Optional configurationfile for 3rd party auto brightnes / color temperature
CFG_FILE=""
if nothing else is automatically controlling monitors comment out next line
CFG_FILE=/usr/local/bin/.eyesome-cfg
DisableAutoBright () { # Disable specific monitors from nightlight, redshift, flux, eyesome, ect. [[ $CFG_FILE == "" ]] && return # No third party apps [[ $MON1 != "" ]] && sed -i 's/1|Enabled/1|Disabled/g' "$CFG_FILE" [[ $MON2 != "" ]] && sed -i 's/2|Enabled/2|Disabled/g' "$CFG_FILE" [[ $MON3 != "" ]] && sed -i 's/3|Enabled/3|Disabled/g' "$CFG_FILE" } # DisableAutoBright
EnableAutoBright () { # Renable specific monitors for nightlight, redshift, flux, eyesome, ect. [[ $CFG_FILE == "" ]] && return # No third party apps [[ $MON1 != "" ]] && sed -i 's/1|Disabled/1|Enabled/g' "$CFG_FILE" [[ $MON2 != "" ]] && sed -i 's/2|Disabled/2|Enabled/g' "$CFG_FILE" [[ $MON3 != "" ]] && sed -i 's/3|Disabled/3|Enabled/g' "$CFG_FILE"
# Trigger 3rd party app to gradually set brightness based on sunrise/sunset
/usr/local/bin/wake-eyesome.sh post eyesome-cfg.sh nosleep
} # EnableAutoBright
MonArr=() # Index 0= Monitor # 1 to 3, 1=Xrandr Name, 2=Connected/Disconnected, # 3=Save Bright "100"=1.0, 4=Current Bright "75"=0.75, 5=xprintidle cnt
PaintStats () {
local i Image
Image=( \
&quot;╔═══════════════════════════════════════════════════════════════════╗&quot;
&quot;║   movie.sh - Dim specific monitors when keyboard and mouse idle   ║&quot;
&quot;╠═════════════════════════════════╤═════════════════════════════════╣&quot;
&quot;║         Active Stats            │         Dimmed Stats            ║&quot;
&quot;╟─────────────────────────────────┼─────────────────────────────────╢&quot;
&quot;║ Total time:   1:30:22 (H:M:S)   │ Total Time:   0:30:25 (H:M:S)   ║&quot;
&quot;║ Cycle Count:  999 cycles        │ Cycle Count:  999 cycles        ║&quot;
&quot;║ Total checks: 9,999,999 checks  │ Total checks: 9,999,999 checks  ║&quot;
&quot;║ This cycle:   99 Hours 99 Secs  │ Last cycle:   99 Hours 99 Secs  ║&quot;
&quot;║ Last check:   Sat 1:52:39 pm    │ Dim started:  Sat 12:42:15 pm   ║&quot;
&quot;║ Sleeping:     200 Seconds       │ Short wakes:  999 pause/plays   ║&quot;
&quot;║ Next check:   Sat 1:53:49 pm    │ Dim ended:    Sat 1:31:08 pm    ║&quot;
&quot;╚═════════════════════════════════╧═════════════════════════════════╝&quot;
echo -e &quot;\033[32m&quot;  # Start green text
for i in &quot;${Image[@]}&quot; ; do echo &quot;$i&quot; ; done
echo -e &quot;\033[0m&quot;   # End green text
} # PaintStats
PrintStr () { tput cup "$1" "$2" ; echo -e " " tput cup "$1" "$2" ; echo -e "$3" } # PrintStr
PrintDig () { tput cup "$1" "$2" ; echo -e " " tput cup "$1" "$2" ; printf "%'d %s" "$3" "$4" } # PrintDig
PrintDur () {
local h m s FormattedElapsed
(( h = ${3} / 3600 ))
(( m = (${3}%3600) / 60 ))
(( s = ${3}%60 ))
FormattedElapsed=&quot;$h:$m:$s (H:M:S)&quot;
FormattedElapsed=&quot;$h&quot;&quot;hr $m&quot;&quot;mn $s&quot;&quot;sc&quot;
tput cup &quot;$1&quot; &quot;$2&quot; ; echo -e &quot;                 &quot;
PrintStr &quot;$1&quot; &quot;$2&quot; &quot;$FormattedElapsed&quot;
} # PrintDur
TotalActive=0 TotalDimmed=0 ActiveCount=1 # We are already active starting up DimmedCount=0 ActiveChecks=0 DimmedChecks=0 ThisActiveTime=0 LastDimmedTime=0 LastActiveCheck="" LastDimStarted="" ActiveSleepTime=0 ShortCount=0 NextActiveCheck="" LastDimEnded=""
UpdateStats () {
tput sc             # Save Cursor
echo -e &quot;\033[36m&quot;  # Start cyan text
PrintDur  6 16 &quot;$TotalActive&quot;
PrintDur  6 50 &quot;$TotalDimmed&quot;
PrintDig  7 16 &quot;$ActiveCount&quot; &quot;cycles&quot;
PrintDig  7 50 &quot;$DimmedCount&quot; &quot;cycles&quot;
PrintDig  8 16 &quot;$ActiveChecks&quot; &quot;checks&quot;
PrintDig  8 50 &quot;$DimmedChecks&quot; &quot;checks&quot;
PrintDur 10 16 &quot;$ThisActiveTime&quot;
PrintDur 10 50 &quot;$LastDimmedTime&quot;
PrintStr 11 16 &quot;$LastActiveCheck&quot;
PrintStr 11 50 &quot;$LastDimStarted&quot;
PrintStr 12 16 &quot;$ActiveSleepTime Seconds&quot;
PrintDig 12 50 &quot;$ShortCount&quot; &quot;pause/plays&quot;
PrintStr 13 16 &quot;$NextActiveCheck&quot;
PrintStr 13 50 &quot;$LastDimEnded&quot;
echo -e &quot;\033[0m&quot;   # End cyan text
tput rc             # Restore cursor
UpdateStats
SetBrightness () {
# Parm 1: XrandrMonitor Name
# Parm 2: Math Brigthness Value
local MON CurrBright
MON=&quot;$1&quot;
MathBright=&quot;$2&quot;
[[ &quot;${MathBright:0:1}&quot; == &quot;-&quot; ]] &amp;&amp; MathBright=0    # Negative not allowed
[[ &quot;$MathBright&quot; -gt 999  ]] &amp;&amp; MathBright=999      # Can't go over 9.99
if [[ &quot;${#MathBright}&quot; -eq 3 ]] ; then
    MathBright=&quot;$MathBright&quot;000         # Pad with lots of zeros
    CurrBright=&quot;${MathBright:0:1}.${MathBright:1:2}&quot;
elif [[ &quot;${#MathBright}&quot; -eq 1 ]] ; then
    CurrBright=&quot;.0$MathBright&quot;
else
    CurrBright=&quot;.${MathBright:0:2}&quot;
fi
# Even if brigthness hasn't changed we want to set it each time so
# that `xrandr` will lag sleep cycle by 25 milliseconds
if [[ $CurrBright == &quot;.0&quot; ]] ; then
    xrandr --output &quot;$MON&quot; --off
else
    xrandr --output &quot;$MON&quot; --brightness &quot;$CurrBright&quot;   # Set new brightness
fi
} # SetBrightness
GetCurrBright () {
# Call this before starting to fade monitor. Parm1: Monitor Xrandr name
# Setup for global variables failure
MonMathBright=&quot;0&quot;
MonCurrBright=&quot;0.0&quot;
MonStatus=&quot;Disconnected&quot;
[[ $1 == &quot;&quot; ]] &amp;&amp; return
local CurrBright Left Right
CurrBright=$( xrandr --verbose --current | \
                                  grep ^&quot;$1 connected&quot; -A5 | tail -n1 )
[[ $CurrBright == &quot;&quot; ]] &amp;&amp; { echo &quot;$1 Monitor not found in xorg&quot;; return; }
MonStatus=&quot;Connected&quot;
MonCurrBright=&quot;${CurrBright##* }&quot;  # Get brightness level with decimal place
Left=${MonCurrBright%%&quot;.&quot;*}        # Extract left of decimal point
Right=${MonCurrBright#*&quot;.&quot;}        # Extract right of decimal point
[[ &quot;$Left&quot; != 0 ]] &amp;&amp; MonMathBright=&quot;$Left&quot;00   # 1.0 becomes &quot;100&quot;
[[ &quot;${#Right}&quot; -eq 1 ]] &amp;&amp; Right=&quot;$Right&quot;0      # 0.5 becomes &quot;50&quot;
MonMathBright=$(( MonMathBright + Right ))
# ((Debug)) &amp;&amp; echo &quot;$MonName Starting brightness: $MonMathBright&quot;
} # GetCurrBright
ConvertSeconds () {
# Credit: https://stackoverflow.com/a/12199798/6929343
local h m s
((h=${1}/3600))
((m=(${1}%3600)/60))
((s=${1}%60))
printf &quot;Monitor(s) dimmed for: &quot;
[[ $h -gt 0 ]] &amp;&amp; printf &quot;%d Hour(s) &quot; $h
[[ $m -gt 0 ]] &amp;&amp; printf &quot;%d Minute(s) &quot; $m
printf &quot;%2d Second(s)\n&quot; $s
} # ConvertSeconds
IgnoreShortWake () {
# If this was just an accidental mouse movement or a singe Enter key to
# pause / play movie then return false (1).
local LastElapsed ShortTime
LastElapsed=$(xprintidle)
while true ; do
    sleep .1
    ShortTime=$(xprintidle)
    [[ $ShortTime -lt &quot;$LastElapsed&quot; ]] &amp;&amp; return 0 # Real wakeup
    # User clicked play/pausse, incrment count and go back to sleep
    [[ $ShortTime -ge 3000           ]] &amp;&amp; { (( ShortCount++ )); return 1; }
    LastElapsed=&quot;$ShortTime&quot;
done
} # IgnoreShortWake
BrightenMonitors () {
# If short mouse movement or single key press go back to sleep
IgnoreShortWake
[[ &quot;$?&quot; == &quot;1&quot; ]] &amp;&amp; return 1   # Monitors not brightened
# How long were we dimmed for?
DimmingEnded=&quot;$SECONDS&quot;
DimmingDuration=$(( DimmingEnded - DimmingStarted ))
TotalDimmed=$(( TotalDimmed + DimmingDuration ))
(( ActiveCount++ ))
ThisActiveTime=0
# Turn monitor on and slowly raise brightness to saved setting
[[ &quot;$BACK&quot; != &quot;&quot; &amp;&amp; &quot;$BackOff&quot; == true ]] &amp;&amp; \
    echo 0 &gt; &quot;/sys/class/backlight/$BACK/bl_power&quot;
BackOff=false
local i m LastPercent NewMathBright
LastPercent=0
for (( m = 0 ; m &lt; MonArrCnt ; m=m+MON_COL_CNT )); do   #loop for each monitor
    GetByNdx &quot;$m&quot;
    [[ $MonStatus == Disconnected ]] &amp;&amp; continue
    # If dimming interrupted, start from last percentage and not 0%
    [[ $MonPercent -gt &quot;$LastPercent&quot; ]] &amp;&amp; LastPercent=&quot;$MonPercent&quot;
done
if ((Debug)) ; then
echo Starting percentage: "$LastPercent"
ConvertSeconds "$DimmingDuration"
fi
# Brighten by increments of 4% for quicker waking
for (( i = LastPercent ; i &lt;= 100 ; i=i+4 )); do    # loop from 0% to 100%
    [[ $i -ge 96 ]] &amp;&amp; i=100 # If 96, next loop will be 100
        [[ $MonMathBright -eq 0 ]] &amp;&amp; MonMathBright=1
        NewMathBright=$(( MonMathBright * i / 100 ))
        SetBrightness &quot;$MonName&quot; &quot;$NewMathBright&quot;
        SetByNdx &quot;$m&quot;
        sleep &quot;$WAKE_SLEEP&quot;       # Very quick increase, so smaller sleep
    done
done
LastDimEnded=$(date +'%a %I:%M:%S %P')
return 0        # Monitors were brigthened
} # BrightenMonitors
DimMonitors () {
DimmingStarted=&quot;$SECONDS&quot;
LastDimmedTime=0
(( DimmedCount++ ))
local i m NewMathBright Elapsed
    # Get starting full brightness level, blank monitor name returns zeros
    GetCurrBright &quot;$MonName&quot;
done
# Dim by increments of 1% for slow fading
for (( i = 100 ; i &gt;= 0 ; i-- )); do    # loop from 100% to 0% brightness
        MonPercent=&quot;$i&quot;
    done
    sleep &quot;$FADE_SLEEP&quot;         # slowly dim so longer sleep
    [[ $Elapsed -lt 2000 ]] &amp;&amp; return
done
# Completely turn off laptop's backlight for &quot;full black&quot;
[[ &quot;$BACK&quot; != &quot;&quot; ]] &amp;&amp; echo 4 &gt; &quot;/sys/class/backlight/$BACK/bl_power&quot;
BackOff=true
LastDimStarted=$(date +'%a %I:%M:%S %P')
} # DimMonitors
GetByNdx () { # Parm1 = index number, 0 = first monitor array entry MonNumber="${MonArr[$1]}" # 3rd party monitor number, eg "3" MonName="${MonArr[$1+1]}" # Xrandr Monitor name, eg "DP-1-1" MonStatus="${MonArr[$1+2]}" # Xrandr Connected/Disconnected MonCurrBright="${MonArr[$1+3]}" # Value when dimming first starts eg 1.00 MonMathBright="${MonArr[$1+4]}" # Math implied decimal 100 = 1.00, 50 = .5 MonPercent="${MonArr[$1+5]}" # Last percentage brightness set } # GetByNdx
SetByNdx () { # Parm1 = index number, 0 = first monitor array entry MonArr[$1]="$MonNumber" # 3rd party monitor number, eg "3" MonArr[$1+1]="$MonName" # Xrandr Monitor name, eg "DP-1-1" MonArr[$1+2]="$MonStatus" # Xrandr Connected/Disconnected MonArr[$1+3]="$MonCurrBright" # Value when dimming first starts eg 1.00 MonArr[$1+4]="$MonMathBright" # Implied decimal 100 = 1.00, 50 = .5 MonArr[$1+5]="$MonPercent" # Last percentage brightness set } # SetByNdx
InitializeMonArr () {
# Initialize arrays with Xrandr name, status, curret bright, math bright, %
MonArr=()
MonArr+=( &quot;1&quot; &quot;$MON1&quot; &quot;Cconnected&quot; &quot;1.0&quot; &quot;100&quot; &quot;0&quot; )
MonArr+=( &quot;2&quot; &quot;$MON2&quot; &quot;Disconnected&quot; &quot;.0&quot; &quot;0&quot; &quot;0&quot; )
MonArr+=( &quot;3&quot; &quot;$MON3&quot; &quot;Connected&quot; &quot;1.0&quot; &quot;100&quot; &quot;0&quot; )
MON_COL_CNT=6
MonArrCnt=&quot;${#MonArr[@]}&quot;
# Dummy calls, but may not be necessary, test with delete later
GetByNdx 0
SetByNdx 0
} # InitializeMonArr
clear PaintStats
Dimmed=false InitializeMonArr if ((Debug)) ; then echo "" echo "$(date +'%A %I:%M:%S %P') Starting movie.sh" echo "" echo "Monitor Array Dump: #, Name, Curr Bright, Math Bright, Last Percent" echo "${MonArr[*]}" echo "" fi
Loop until CTRL + C
while true ; do
UpdateStats
if [[ $Elapsed -lt &quot;$TIME_TO_WAKE&quot; ]] ; then
    if [[ $Dimmed == true ]] ; then
        # ((Debug)) &amp;&amp; echo -e $'\n'&quot;$(date) Wake after: $Elapsed milliseconds&quot;
        TotalDimmed=$(( Elapsed / 1000 + TotalDimmed ))
        (( DimmedCount++ ))
        BrightenMonitors
        if [[ &quot;$?&quot; == &quot;0&quot; ]] ; then
            EnableAutoBright
            Dimmed=false
        else
            Elapsed=0       # Calculate new full sleep cycle below
        fi
    fi
elif [[ $Elapsed -gt &quot;$TIME_TO_FADE&quot; ]] ; then
    if [[ $Dimmed == false ]] ; then
        # ((Debug)) &amp;&amp; echo -e $'\n'&quot;$(date) Fade after: $Elapsed milliseconds&quot;
        TotalActive=$(( Elapsed / 1000 + TotalActive ))
        Dimmed=true
        DisableAutoBright
        DimMonitors
        continue    # Double check in case mouse moved during fade.
    fi
fi
if [[ &quot;$Dimmed&quot; == true ]] ; then
    # Be prepared to respond relatively instantly to mouse movement
    sleep 1
    (( DimmedChecks++ ))
    DimmedTime=$(( DimmedTime + 1 ))
    LastDimmedTime=$(( LastDimmedTime + 1 ))
else
    # sleep until time to test for monitor fade
    SleepTime=$(( (TIME_TO_FADE - Elapsed + 1000) / 1000 ))
    [[ &quot;$SleepTime&quot; -lt 1 ]] &amp;&amp; SleepTime=1
    # ((Debug)) &amp;&amp; echo &quot;$(date) Sleeping until next fade check: $SleepTime seconds&quot;
    LastActiveCheck=$(date +'%a %I:%M:%S %P')
    ActiveSleepTime=$SleepTime
    NextActiveCheck=$(date +'%a %I:%M:%S %P' --date &quot;$SleepTime seconds&quot;)
    ActiveTime=$(( ActiveTime + SleepTime ))
    TotalActive=$(( TotalActive + SleepTime ))
    (( ActiveChecks++ ))
    ThisActiveTime=$(( ThisActiveTime + SleepTime ))
    UpdateStats
    sleep &quot;$SleepTime&quot;
fi
done
