17
I want to delete my Linux kernel but still want to run Ubuntu with GNU utilities. I don't like Linux; I only want GNU. So can I run Ubuntu and GNU on something other than Linux kernel?
5 Answers5
27
TL;DR
You cannot remove the Linux kernel from Ubuntu, without irrevocably crashing your entire system but in the future you might be able to replace it.
The long answer:
This is due to the history of GNU/Linux:
Once upon a time, there was a guy called RMS that wanted to keep software to be free¹. He ended up publishing the source of his software (what we call "Open-Sourcing" today) and eventually this all became the GNU Core Utilities after a few other people helped him out.
However, these utilities missed just one little thing to be 100% free and that was a Kernel to run on as the GNU Utilities were running on UNIX System V and its clones and this is where we bring Linus Torvalds in: he developed a Monolithic Kernel² and published his source too with the understatement of the XXth century:
I'm doing a (free) operating system (just a hobby, won't be big and professional like gnu) for 386(486) AT clones.³
The kernel is the bit of software that talks to the hardware, so manages the Memory, Disks, Keyboard, Mouse, Screen, Display Adapter, Speakers, Webcam, ... so you cannot run any OS without some kind of kernel.
Fast forward a quarter of a century and the GNU Utilities still run on that same kernel (in the meantime named "Linux")
Ubuntu = Linux Kernel + GNU Core Utilities + a ton of other software.⁴
So: No, today you cannot delete the kernel, but in a few years when the GNU HURD from the Free Software Foundation's⁵ multiserver microkernel comes out of development⁶ you will be able to replace the Linux Kernel with the Hurd one but you can never run any OS without some kind of kernel.
Alternatively,
You can run the GNU Core Utilities on another OS entirely:
  • BSD or one of its variants: MacOS
  • Windows (32-bit only)
But these also have kernels, though none of the above use Linux kernels.
Note 1: "Free" as in Freedom, not Free beer ;-).
Note 2: GNU Hurd took the decision to go for a multiserver microkernel because they wanted the kernel to be distributed amongst multiple machines because RAM was so expensive at the time.
Note 3: OK, maybe Houston, we have a problem is the biggest understatement of the century...
Note 4: I.E. All the software you install yourself. :-).
Note 5: the FSF is the copyright holder of the GNU Core Utilities.
Note 6: The GNU Hurd multiserver microkernel has been in development for 20+ years, so don't expect anything in the next couple of years (maybe decades)
Note 7: Please be aware that changing Ubuntu's Linux Kernel would make the concoction you just created off-topic on this site! (As it would not be Ubuntu any more)
Fabby
  • 35,017
11
You have to have an Operating System. Because this site is called Ask Ubuntu your question must be reinterpreted to fit into the rules:
  • What operating systems (kernels) other than Linux Kernel will Ubuntu run on?
One answer would be Windows 10 with the WSL (Windows Subsystem for Linux) option turned on. You can also run most, if not all, the GNU utilities there. Extra steps are needed though to run the Ubuntu GUI desktop in Windows 10:
Yes, such project already exists
UbuntuBSD brings together FreeBSD kernel and Ubuntu userspace. This project has been covered in several Linux online journals, including itsfoss. While the project has been discontinued, you can still use the last available version.
Please note that this distro would be off-topic here, as discussed multiple times on Meta site, since this is NOT an official Ubuntu flavor
TL;DR
Theoretically, yes; practically, it'd be really hard.
The long version:
You could, in theory, run Ubuntu on a non-Linux kernel, but due to the fact that not all kernels use the same executable format, you would need to download gigabytes of source code and compile every single bit of it, and rearrange files to satisfy the new kernel.
Otherwise, a non-binary compatible kernel would try to run systemd/init and find an unintelligible sequence of bytes, and crash with the cryptic message:
cannot execute binary file: Exec format error
@fabby has the right idea. But doesn’t really answer the question
wsl 1 is your best bet. With Windows 10+ pro, make sure wsl defaults to v1
Then install Ubuntu for Windows using the Windows Store or a direct download (beware of malware versions)
Then setup the xsvrc (on iphone, so I can’t look this up) or wgsl on windows. This will allow remote desktop xorg.
Install the desktop or xutils for xeyes. Have xorg config use :0. And the UI will pop up on windows. Even a full desktop of you launch it.
Avoid cygwin at all cost. It has been deprecated forever
MSYS/mingw allows windows to use gnu commands under windows. Easiest way is to install git. And select to add Unix Command Line tools to PATH
But that is a far cry from the full-blown Ubuntu for Windows (or one of the many other distro’s) on wsl 1
wsl 1 is still in active development. WSL 2 has its place too. It uses a VM. But they are both independent. Both useful
wsl 1 works great on remote vm that doesn’t allow virtualization. Or if your company locks your bios and doesn’t have virtualization enabled
wsl1 is supported - https://discourse.ubuntu.com/t/ubuntu-20-04-and-wsl-1/15291?_ga=2.162530940.1522240380.1695010667-800046954.1695010667
wsl1 vs wsl2 information (wsl1 uses less resources than wsl2) https://wiki.ubuntu.com/WSL?_ga=2.161401213.1522240380.1695010667-800046954.1695010667
