I'm trying to install InkScape on Ubuntu 19.04 from Discover (KDE plasma store), but it shows error:
Dependencies resolution failed
I tried installing it from PPA
sudo add-apt-repository ppa:inkscape.dev/stable
sudo apt install inkscape -y
but it still shows dependencies unmet. This package or dependency is unmet.
inkscape : Depends: libpoppler82 (>= 0.71.0) but it is not installable
            Recommends: python-uniconvertor but it is not installable
How to install it, I can't find any solution. Any help will be appreciated.
pLumo
  • 27,991
Arman Khan
  • 43
Both the disco repositories and the ppa currently provide version 0.92.4.
So you don't need the ppa, remove it:
sudo add-apt-repository -r ppa:inkscape.dev/stable
then update your repositories:
sudo apt update
and to fix some potential dependency issues (might not be needed, but it's always safe to run):
sudo apt install -f
then install inkscape:
pLumo
  • 27,991
