I have a sandbox Ubuntu server VM (virtualbox) with a single drive. Recently I needed to extend the disk space of the server, so I created a second disk. I dd'd the original /dev/sda to the new /dev/sdb and extended the partition size with parted and resize2fs. Everything looks great, so now I want to make the /dev/sdb partition default and remove the /dev/sda. How do I make the /dev/sdb the default boot option? Currently I can only boot into it from a rescuecd, the default boot option is /dev/sda
lsblk output (booted from /dev/sdb via rescuecd):
[12:10] [vhost2 ~] # lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 10G 0 disk
├─sda1 8:1 0 1M 0 part
└─sda2 8:2 0 10G 0 part
sdb 8:16 0 20G 0 disk
├─sdb1 8:17 0 1M 0 part
└─sdb2 8:18 0 18.6G 0 part /
fdisk output:
[12:10] [vhost2 ~] # fdisk -l
Disk /dev/sda: 10 GiB, 10737418240 bytes, 20971520 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 4E763705-333C-4EE0-80EB-782C5D968F03
Device Start End Sectors Size Type
/dev/sda1 2048 4095 2048 1M BIOS boot
/dev/sda2 4096 20969471 20965376 10G Linux filesystem
Disk /dev/sdb: 20 GiB, 21474836480 bytes, 41943040 sectors
Disklabel type: gpt
/dev/sdb1 2048 4095 2048 1M BIOS boot
/dev/sdb2 4096 39062500 39058405 18.6G Linux filesystem
My fstab is empty
[12:11] [vhost2 ~] # cat /etc/fstab
UUID=88fdcaac-dcfd-4f0e-99de-5adf19d4ab12 / ext4 defaults 0 0
/swap.img none swap sw 0 0
