-1
I had a problem with my left audio front panel and I was trying to fix it. I searched for a solution for my problem in other sites and I execute a code to eliminate the pulse folder. However, the system settings and the control volume are missing now. I try to install gnome and pavucontrol. But the system returns the same message:
$ sudo apt-get install pavucontrol
Unable to fetch some archives, maybe run apt-get update or try with --fix-missing
P.S. My Ubuntu is 17.10
Simon Sudler
  • 4,111
Cássia
Run sudo apt-get update first and then try sudo apt-get update --fix-missing.
If the Problem ist still there, you should consider upgrading to a newer version of Ubuntu, since 17.10 is not longer maintained.
Simon Sudler
  • 4,111
