I'm very new to KDE (running Kubuntu 18.10) and want to be able to quickly toggle grayscale through the terminal. I can make the script to do this but I don't know what to call to toggle the Desktop Effect.
Currently I'm using the extension described in this answer from this Github reop. Everything works great, the only problem is that I want to quickly switch to grayscale instead of going into System Settings > Desktop Behavior >Desktop Effects and click Apply. This is way to many steps for me to use more than once or twice a day.
My question is what command do I call to toggle this from the command line so I can write a script to do this?
I'm looking at the qdbus and trying something like:
qdbus org.kde.KWwin /Effects toggleEffect Grayscale
But nothing happens.
fizzyh2o
  • 113
This doesn't deserve an answer, but I don't have the reputation to comment.
I'm trying to automate grayscale toggling via a shortcut too, and sometimes the set:
kwriteconfig5 --file ~/.config/kwinrc --group Plugins --key kwin4_effect_grayscaleEnabled "false"
qdbus org.kde.KWin /KWin reconfigure
doesn't work (effect is not disabling, even if visibly unchecked in the settings).
So I just add an extra line:
qdbus org.kde.KWin /Compositor suspend && qdbus org.kde.KWin /Compositor resume
(it reloads the compositor, the same as doing "alt+shift+F12" twice)
And this allows to avoid the heavy kwin_x11 --replace solution, so I think it's better (but I'm absolutely no expert here).
(Note that I had to add a sleep 0.2 in between the two lines too, otherwise the grayscale disabling didn't work unless I triggered the whole thing a second time)
NoGa
  • 26
If you are still interested in the DBUS answer, which its a bit less complicated, you can try this:
#Enable the Effect:
qdbus --literal org.kde.KWin /Effects org.kde.kwin.Effects.loadEffect kwin4_effect_grayscale
#Disable the Effect: qdbus --literal org.kde.KWin /Effects org.kde.kwin.Effects.unloadEffect kwin4_effect_grayscale
#Toggle the Effect state: qdbus --literal org.kde.KWin /Effects org.kde.kwin.Effects.toggleEffect kwin4_effect_grayscale
