I wanted to install the new R version so I did a purge by removing all r-*. And then I broke everything unfortunately. I try to reinstall R project by typing
sudo apt install r-base r-base-core r-recommended
and then I obtain
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable
 The following packages have unmet dependencies.
 r-base-core : Depends: libc6 (>= 2.27) but 2.23-0ubuntu11 is to be
               installed
               Depends: libcurl4 (>= 7.28.0) but it is not installable
               Depends: libicu60 (>= 60.1-1~) but it is not installable
               Depends: libreadline7 (>= 6.0) but it is not installable
               Recommends: r-base-dev but it is not going to be installed
Does anyone know how to solve this ?
Pablo Bianchi
  • 17,371
Akusa
  • 311
My problem is solved.
I had put the wrong source in my sources.list to download the latest version of R. Following the instructions given in https://cloud.r-project.org/, I had put deb https://cloud.r-project.org/bin/linux/ubuntu cosmic-cran35/ instead of deb https://cloud.r-project.org/bin/linux/ubuntu xenial-cran35/.
By modifying the source, everything works fine now.
Akusa
  • 311
So here is how to install R 3.6 on your current Ubuntu distribution, without having to manually adjust the distribution name or
sudo apt-get update
sudo apt-get install -y apt-transport-https software-properties-common
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys E298A3A825C0D65DFD57CBB651716619E084DAB9
# this will define the DISTRIB_* environment variables
source /etc/lsb-release
sudo add-apt-repository "deb https://cloud.r-project.org/bin/linux/ubuntu ${DISTRIB_CODENAME}-cran35/"
# for 18.04, bionic beaver, this resolves to
#sudo add-apt-repository 'deb https://cloud.r-project.org/bin/linux/ubuntu bionic-cran35/'
# for 16.04, xenial, this resolves to
#sudo add-apt-repository 'deb https://cloud.r-project.org/bin/linux/ubuntu xenial-cran35/'
sudo apt-get update
sudo apt-get install -y r-base r-base-dev
R --version
Rscript --version
This should eliminate the error messages that arise from you choosing the wrong distribution like:
               installed
Inspired by
Try this:
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install libc6 libcurl4 libicu60-dev libreadline7
sudo apt-get install r-base r-base-core r-recommended
