I've been trying without success to upgrade R in my Ubuntu 16.04 from 3.4 to the latest version in order to install some packages. Following some solutions, I did a purge by removing all r-*. then everything broke. I tried to install it again, but mistakenly, I've put the wrong source deb https://cloud.r-project.org/bin/linux/ubuntu focal-cran40/ instead of deb https://cloud.r-project.org/bin/linux/ubuntu xenial-cran40/ as I have 16.04
I followed many suggestions to fix it and install R again (like this, this and this) but nothing worked and I am unable to install it again!
How I tried to install the complete R system:
sudo apt purge r-base* r-recommended r-cran-*
sudo apt autoremove
sudo apt-get update
Err:28 https://cloud.r-project.org/bin/linux/ubuntu disco-cran35/ Packages 404 Not Found Ign:29 https://cloud.r-project.org/bin/linux/ubuntu disco-cran35/ Translation-en_US Ign:30 https://cloud.r-project.org/bin/linux/ubuntu disco-cran35/ Translation-en Err:31 https://cloud.r-project.org/bin/linux/ubuntu xenial-cran36/ Packages 404 Not Found Ign:32 https://cloud.r-project.org/bin/linux/ubuntu xenial-cran36/ Translation-en_US Ign:33 https://cloud.r-project.org/bin/linux/ubuntu xenial-cran36/ Translation-en Fetched 465 kB in 4s (95,2 kB/s) Reading package lists... Done W: The repository 'http://ppa.launchpad.net/jonathonf/python-3.6/ubuntu xenial Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. W: The repository 'https://cloud.r-project.org/bin/linux/ubuntu disco-cran35/ Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. W: The repository 'https://cloud.r-project.org/bin/linux/ubuntu xenial-cran36/ Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. E: Failed to fetch http://ppa.launchpad.net/jonathonf/python-3.6/ubuntu/dists/xenial/main/binary-amd64/Packages 403 Forbidden [IP: 91.189.95.83 80] E: Failed to fetch https://cloud.r-project.org/bin/linux/ubuntu/disco-cran35/Packages 404 Not Found E: Failed to fetch https://cloud.r-project.org/bin/linux/ubuntu/xenial-cran36/Packages 404 Not Found E: Some index files failed to download. They have been ignored, or old ones used instead.
sudo apt-get install r-base
Reading package lists... Done Building dependency tree
Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: r-base : Depends: r-base-core (>= 4.0.2-1.2004.0) but it is not going to be installed Depends: r-recommended (= 4.0.2-1.2004.0) but it is not going to be installed Recommends: r-base-html but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Although that R complete system is not installed, I tried to obtain the latest R 4.0 packages as
sudo apt autoremove
sudo add-apt-repository 'deb https://cloud.r-project.org/bin/linux/ubuntu xenial-cran40/'
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys E298A3A825C0D65DFD57CBB651716619E084DAB9
sudo apt update
Hit:1 http://linux.teamviewer.com/deb stable InRelease Hit:2 http://dl.google.com/linux/chrome/deb stable InRelease
Get:3 http://ubuntu.mirrors.ovh.net/ftp.ubuntu.com/ubuntu xenial InRelease [247 kB] Ign:4 http://ppa.launchpad.net/jonathonf/python-3.6/ubuntu xenial InRelease
Hit:5 https://dl.yarnpkg.com/debian stable InRelease
Hit:6 http://archive.canonical.com xenial InRelease
Hit:7 http://ppa.launchpad.net/webupd8team/sublime-text-3/ubuntu xenial InRelease Hit:8 https://cloud.r-project.org/bin/linux/ubuntu focal-cran40/ InRelease
Hit:9 https://cran.rstudio.com/bin/linux/ubuntu xenial/ InRelease
Err:10 http://ppa.launchpad.net/jonathonf/python-3.6/ubuntu xenial Release
403 Forbidden [IP: 91.189.95.83 80] Hit:11 https://pbil.univ-lyon1.fr/CRAN/bin/linux/ubuntu xenial/ InRelease
Hit:12 https://cloud.r-project.org/bin/linux/ubuntu bionic-cran40/ InRelease Hit:13 https://cloud.r-project.org/bin/linux/ubuntu xenial-cran40/ InRelease Get:14 http://ubuntu.mirrors.ovh.net/ftp.ubuntu.com/ubuntu xenial-security InRelease [109 kB] Hit:15 https://repo.skype.com/deb stable InRelease
Get:16 http://ubuntu.mirrors.ovh.net/ftp.ubuntu.com/ubuntu xenial-updates InRelease [109 kB] Ign:17 https://cloud.r-project.org/bin/linux/ubuntu disco-cran35/ InRelease Hit:18 https://cloud.r-project.org/bin/linux/ubuntu xenial-cran35/ InRelease Ign:19 https://cloud.r-project.org/bin/linux/ubuntu xenial-cran36/ InRelease Hit:20 https://cloud.r-project.org/bin/linux/ubuntu xenial/ InRelease Err:21 https://cloud.r-project.org/bin/linux/ubuntu disco-cran35/ Release 404 Not Found Err:22 https://cloud.r-project.org/bin/linux/ubuntu xenial-cran36/ Release 404 Not Found Hit:23 https://packagecloud.io/slacktechnologies/slack/debian jessie InRelease Reading package lists... Done W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:69 W: Target Translations (en_US) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:69 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:69 W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:71 W: Target Translations (en_US) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:71 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:71 E: The repository 'http://ppa.launchpad.net/jonathonf/python-3.6/ubuntu xenial Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'https://cloud.r-project.org/bin/linux/ubuntu disco-cran35/ Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'https://cloud.r-project.org/bin/linux/ubuntu xenial-cran36/ Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:69 W: Target Translations (en_US) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:69 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:69 W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:71 W: Target Translations (en_US) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:71 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:61 and /etc/apt/sources.list:71
sudo apt install r-base-dev
The following packages have unmet dependencies: r-base-dev : Depends: r-base-core (>= 4.0.2-1.2004.0) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Could you please help me to install again R
Edit: Adding the following lines didn't help!
sudo apt --fix-broken install
sudo apt autoremove
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install r-base-dev
