I have tried every conceivable way of installing R on this server and it will not work all I get is the below error. I realize this has been posted a few times but none of the approved answers work for me. I'm new to ubuntu so please help. This is very frustrating.
r-base : Depends: r-base-core (>= 3.6.1-3bionic) but it is not going to be installed
Depends: r-recommended (= 3.6.1-3bionic) but it is not going to be installed
Recommends: r-base-html but it is not going to be installed
I then tried to manually install r-base-core and got
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an
The following packages have unmet dependencies.
r-base-core : Depends: libc6 (>= 2.27) but 2.23-0ubuntu11 is to be
installed
Depends: libcurl4 (>= 7.28.0) but it is not installable
Depends: libicu60 (>= 60.1-1~) but it is not installable
Depends: libreadline7 (>= 6.0) but it is not installable
Recommends: r-base-dev but it is not going to be installed
I then tried tried to install libcurl4 and got
Package libcurl4 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source.
The other packages produce identical errors.
Again please keep it in layman's terms I'm well out of my depth.
