I am on Ubuntu Snap server with no GUI and would like to remap my caps-lock to escape for my terminal sessions. I have tried modifying the /etc/defaults/keyboard to include caps:escape but there’s no change to the caps lock function.
Maybe some other things to note: I am trying to do this from an iPad Pro using Apple’s “Folio Keyboard”. IOS gives no option to remap but I was hoping that there was a way on the server.
Thanks
austinbv
  • 1,983
It's not completely clear if you are on a client or on the server so let me try to distinguish.
If you ssh from another machine then input from keystrokes are handled by your SSH terminal application on the client machine, not by anything on the server.
So would be enough to change the keymap on client side like i.e. here.
If Ipad does not allow it I'm afraid you should use another remote terminal or relay on the application you use to remap the keys (if possible). here a quick how-to for vim, emacs has something similar.
For the rest of the answer I'll assume you are logged "on Ubuntu Snap server" not remotely.
There are 2 ways to achieve the same:
  1. through loadkeys (requires console-data to be installed)
dump the layout of your keyboard:
    # dumpkeys >modified.kmap
Modify the layout as needed:
    # in your case you should substitute in the modified.kmap
    #a not elegant way would be to add at the end of the file:
    keycode 1 = Caps_Lock
    keycode 58 = Escape
Apply changes
    # loadkeys ./modified.kmap
Check changes are in place:
    # dumpkeys |grep "Escape"
    keycode  58 = Escape
    # dumpkeys |grep "Caps_Lock"
  1. through a trick with /etc/default/keyboard
Add the following to your layout in /etc/default/keyboard
   XKBOPTIONS="caps:swapescape"
Reconfigure the keyboard through dpkg NB keeping the options (this has to be done also in case your layout is already the correct one)
   # dpkg-reconfigure keyboard-configuration
answer yes when you are asked Keep current keyboard options in the configuration file?
Let me know if this was useful.
The Apple Folio Keyboard doesn't have an Escape key in the first place.
Google searches reveal to imitate Escape one uses CTL+[, FN+[ or CMD+[, depending on the smart keyboard manufacturer for your iPad.
Your first step is to determine which key combination works as the Escape key (ASCII 27, Unicode U+001B, or Ctrl + [) and then map your CAPS lock key to that combination.
