I have a strange problem. On a freshly installed Ubuntu 18.04, the systems seem to work fine. Suddenly, apparently for no reasons, the system hangs up, for 10 seconds or a couple of minutes, and I am unable to perform anything.
I tried to leave a top instance open and the RAM/CPU usage seems to be fine. I am on a i5 machine with 6GB of RAM, and 12GB of swap. I just tested ram and disk and they are error-free.
EDIT Some additional information. I set the CPU frequency governor to performance, so it always work at maximum.
The problem appears more often when performing a CPU intensive operation, such as data analysis. After it finishes, the GUI becomes totally unresponsive, and it's hard or impossible to get it back to work.
EDIT
Output of grep . -r /sys/firmware/acpi/interrupts
/sys/firmware/acpi/interrupts/gpe2F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe23: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe1F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe13: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe0F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe03: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe3D: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe31: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2D: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe21: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe1D: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/ff_pwr_btn: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe11: 0 STS invalid unmasked
/sys/firmware/acpi/interrupts/gpe0D: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe01: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe3B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/ff_rt_clk: 0 disabled unmasked
/sys/firmware/acpi/interrupts/ff_pmtimer: 0 STS invalid unmasked
/sys/firmware/acpi/interrupts/gpe1B: 0 STS invalid unmasked
/sys/firmware/acpi/interrupts/gpe38: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe0B: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe28: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe18: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe08: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe36: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe26: 0 invalid unmasked
/sys/firmware/acpi/interrupts/error: 0
/sys/firmware/acpi/interrupts/gpe16: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/sci: 4
/sys/firmware/acpi/interrupts/gpe06: 4 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe34: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe24: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe14: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe04: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe3E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe32: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe22: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe1E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe12: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe0E: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe02: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe3C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe30: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe20: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe1C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe10: 0 STS invalid unmasked
/sys/firmware/acpi/interrupts/gpe39: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe0C: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe00: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe3A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe_all: 4
/sys/firmware/acpi/interrupts/gpe29: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe19: 0 STS invalid unmasked
/sys/firmware/acpi/interrupts/gpe1A: 0 STS invalid unmasked
/sys/firmware/acpi/interrupts/gpe09: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe37: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe0A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe27: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe17: 0 STS invalid unmasked
/sys/firmware/acpi/interrupts/ff_gbl_lock: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe07: 0 enabled unmasked
/sys/firmware/acpi/interrupts/sci_not: 0
/sys/firmware/acpi/interrupts/gpe35: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe25: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe15: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe05: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe3F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe33: 0 invalid unmasked
/sys/firmware/acpi/interrupts/ff_slp_btn: 0 invalid unmasked
EDIT 04/03/2019 I run a complete SMART test, which now does not look so good, at least in my opinion.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 179 176 021 Pre-fail Always - 4025
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 218
5 Reallocated_Sector_Ct 0x0033 154 154 140 Pre-fail Always - 364
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 034 034 000 Old_age Always - 48741
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 217
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 100
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 117
194 Temperature_Celsius 0x0022 089 080 000 Old_age Always - 58
196 Reallocated_Event_Count 0x0032 022 022 000 Old_age Always - 178
197 Current_Pending_Sector 0x0032 199 199 000 Old_age Always - 234
198 Offline_Uncorrectable 0x0030 199 199 000 Old_age Offline - 245
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 188 188 000 Old_age Offline - 2436
240 Head_Flying_Hours 0x0032 038 038 000 Old_age Always - 45709
241 Total_LBAs_Written 0x0032 200 200 000 Old_age Always - 81196791754
242 Total_LBAs_Read 0x0032 200 200 000 Old_age Always - 75991010629
