The function keys to control the screen brightness - Fn-F11 & Fn-F12 - are not working.
Xubuntu 18.10.
Dell Inspiron 17 7000 (7786) laptop
I have tried updating the boot parameters in /etc/default/grub
Currently running: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset acpi_osi=! "acpi_osi=Windows 2015""
I also tried these options: "acpi_osi=" "acpi_osi=Linux"
Some more checks:
ls -l /sys/class/backlight
...shows nothing.
xrandr --verbose | grep Bright
...shows nothing.
sudo showkey
...shows 224 for Fn-F11 (brightness down) and 225 for Fn-F12 (brightness up).
The other function keys - volume, keyboard backlight, wireless on/off, etc... are working OK.
Ubuntovative is here
  • 1,162
  • 15
  • 41
This solution worked for me:
Taken from:
Brightness fn key shortcut doesn't work on ASUS laptop
and
13.10 Can't Adjust Dell Laptop Backlight
...but not the same.
1. Create file: /usr/share/X11/xorg.conf.d/20-intel.conf
Open terminal and type these commands:
sudo touch /usr/share/X11/xorg.conf.d/20-intel.conf
sudo nano /usr/share/X11/xorg.conf.d/20-intel.conf
Add the following lines to this file:
Section "Device"
    Identifier  "card0"
    Driver      "intel"
    Option      "Backlight"  "intel_backlight"
    BusID       "PCI:0:2:0"
EndSection
Save the file and close nano.
2. Update Grub settings
In a terminal and type these commands:
sudo nano /etc/default/grub
find the line starting with:
and add the option "acpi_backlight=vendor" (without the quotes).
E.g.: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
Save the file and exit nano.
In a in terminal:
sudo update-grub
Restart your laptop and it will work probably...
