25
I was attempting to update my 11.10 install to 12.04beta. During the install step, I accidentally lost power to my laptop (the power cable came unplugged) and it shut down. Whenever I go to boot now, I can select my install via Grub and it loads up to where the sign-in should happen, but I get a display that looks like what you see as soon as you shut down. It looks like it locks after checking for the battery.
Is there anyway, with or without Live media, to restore my machine's install/update to 12.04 but still keep my settings/applications/files?
Ryan McClure
  • 6,119
Did you try booting into the recovery mode (selected via grub)? You could then try to restart the upgrade with
sudo apt-get update
sudo apt-get upgrade
You may need to run
sudo dpkg --configure -a
to fix the partially installed packages.
If the recovery mode is also broken, you could try booting off a live cd and then chroot'ing into your hard drive installation and performing the above steps.
To chroot into your hard drive installation, first boot off a live cd. You can use the ubuntu install CD for this task, just choose the option "try ubuntu" rather than installing. Once booted, open a terminal and mount your root partition. If your root partition is /dev/sda1 (to find out your root partition, there is a guide at https://help.ubuntu.com/community/RecoveringUbuntuAfterInstallingWindows#The_terminal_way):
sudo mkdir -p /media/ubuntu
sudo mount /dev/sda1 /media/ubuntu
Then you need to mount the proc, dev, and sys filesystems into your new environment:
sudo mount --bind /dev /media/ubuntu/dev
sudo mount --bind /proc /media/ubuntu/proc
sudo mount --bind /sys /media/ubuntu/sys
Enable networking:
cp /etc/resolv.conf /media/ubuntu/etc/resolv.conf
Finally, chroot into it:
sudo chroot /media/ubuntu
From here you can run apt-get and dpkg to fix your system. This is identical to the way that people fix grub using chroot, in case you run into problems you can google something like "grub chroot ubuntu livecd" and find more info.
pestilence
  • 1,625
Debian and Ubuntu are similar and for these kind of problems the same solutions works.
During Debian update, my workstation experienced a power lost. Grub worked and MS Windows does, but Debian entry didn't. Setup crashed with an unusual prompt in text mode.
The solution was quite simple. Run the computer with a Debian CD and choosing the Advanced options->Rescue Mode (something like that) on the main and initial menu.
Network is not important.
I chose the option of the bottom "continue without mounting or installing root file system" (this provided reduced functionalities)... but I required just them...
Once in the prompt I used
#fdisk -l to list my partitions.
My root partition was in /dev/sdb1
I used:
#fsck /dev/sdb1
to fix my problem... giving "yes" to all questions.
When it finished I repeated the command. Obtaining in this case no questions and quick finish (because problems were fixed in the first invocation of the command) Just to be sure.
I rebooted my system without the Live CD and it was able to run again the Linux System... during setup many problems with other partitions were found and fixed but the system setup was successful.
I hope this experience will be useful.
