Possible Duplicate:
Lost power during upgrade, how do I recover?
My upgrade from Ubuntu 12.04 to 12.10 got cancelled due to the power being cut off, now Ubuntu is not starting. What can I do? I run windows 7 and Ubuntu. So please help me to get out of this mess because all my files were in Ubuntu. And also I had installed a lot of apps in it. If I loose it I will be in trouble. Please help.
Aditya
  • 103
Press ctrl alt f1 and then login there. after that type as
 sudo dpkg-configure -a
Alvar
  • 17,038
Raja G
  • 105,327
  • 107
  • 262
  • 331
1] If you're able to boot, but after login Unity doesn't load: It's possible that your GPU drivers are interfering; or that your hw isn't 3d-capable. Please post the result of the following command (press CTRL+ALT+T) :
$ /usr/lib/nux/unity_support_test -p
A. If you're using nVidia drivers: Run the following command to remove them, and reboot:
$sudo apt-get purge nvidia-current $sudo apt-get remove nvidia-current-updates $sudo apt-get remove nvidia-experimental-304 Or just open Synaptic and search for nvidia, delete everything that you see now.
Reboot the system. See if everything's working. Run this command to check if Unity-3D will work:
Reboot again. Reinstall latest nVidia drivers:
$ sudo apt-get install nvidia-current-updates
B. If using AMD/ATI GPU drivers: Run the following command to remove them, and reboot:
$ sudo apt-get purge fglrx
Don't reinstall them as ATI cards currently don't support Unity-3D.
2] If you're unable to boot: Insert a Ubuntu 12.10 Live-CD/DVD and run the following commands:
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
Boot-Repair will launch. Select the 'Recommended Repair'.
3] IF you fail to see the Grub:- Insert a Ubuntu 12.10 Live-CD/DVD and run the following commands:
$sudo mount /dev/sdXY /mnt # XY is the drive, eg. sda or sda1
$grub-install /dev/sdX#X is drive number
$update-grub
Reboot. Lemme know if it doesn't work as intended.
TomKat
  • 3,878
