the title says it all: is there a system wide sound enhancer/equalizer with a gui for us? ive tried using a few different sources (pulse) to no avail. any help?
thanks for reading :)
I'm paraphrasing from this answer
The following commands will install PulseEffects on your computer. As you are adding a PPA, you should also know how to remove that PPA.
First, install the program for (eventual) PPA removal:
sudo apt install ppa-purge
Secondly, add the PPA to your system, do an APT update, and then install PulseEffects
sudo add-apt-repository ppa:mikhailnov/pulseeffects -y
sudo apt update
sudo apt install pulseeffects
Finally, should you need to remove PulseEffects:
sudo ppa-purge ppa:mikhailnov/pulseeffects
