I've encouter some problems with my scripts.
So to make it short and clear, I'm in an internship and my boss gave me an assignement to make a Probe for Nagios.
The purpose of this Probe is to check on all our hosts if a package is missing from the repo if yes then we have a Warning on Nagios with the list of missing packages.
This Probe can include a Whitelist if we want to keep a package which is not in whatever repo but we're not using it.
Here is my script:
#!/bin/bash
STATE_OK=0
STATE_WARNING=1
STATE_CRITICAL=2
which apt-show-versions >/dev/null
STATE=$?
declare -a WHITELIST=( host1:elasticsearch:all host2:elasticsearch:all)
PACKAGES=()
NOT_AVAILABLE=()
HOST=$(hostname)
#while [ -f /var/lib/apt/lists/lock ]
#do
#  sleep 2
#done
if [ "$STATE" = 0 ] #Verifie la condition apt-show-version = installer
then
    packets=$(apt-show-versions | grep 'No available version in archive' | cut -d" " -f1)
    for packet in $packets;do
        PACKAGES+=("${HOST}:$packet")
    done
    for package in "${PACKAGES[@]}"; do
        if [ "${WHITELIST[*]}" != "${package}" ]; then
            NOT_AVAILABLE+=("$package")
        fi
    done
    if [ -z "$NOT_AVAILABLE" ]; then
        #Ok dans Nagios
        echo "There is no package without version in archive"
        exit $STATE_OK
    else
        #Warning dans Nagios
        echo "Some package have no available version in archive"
        echo ${NOT_AVAILABLE[*]//"${HOST}":}
        exit $STATE_WARNING
    fi
else
    #Critical dans nagios
    echo "Package apt-show-versions is missing"
    exit $STATE_CRITICAL
fi
And there is the message that is coming frome Nagios :
Remote command execution failed: Failed to open file /var/lib/apt/lists//security.debian.org_dists_stretch_updates_InRelease for reading: Permission denied
I tried to play with lock file in my script but it doesn't work, I got like an infinite loop.
I already gave a look at this question and tried to make a wrapper but he didn't worked or I missed something since I'm student and this is my first step in the shell scripting world.
I looked at this, too but it's kinda old.
EDIT : I found how to do it Thx a lot to all the people trying to help me and specially Sergiy Kolodyazhnyy
So I used APT and DPkg Hooks for that and I had to modify my script to use this hooks.
I create a file named 00apt-show-version in /etc/apt/apt.conf.d/ with this two lines :
APT::Update::Post-Invoke {"apt-show-versions 1>/tmp/nagios_apt_show_versions";};
DPkg::Post-Invoke {"apt-show-versions 1> /tmp/nagios_apt_show_versions";}
Each time apt-get update is called or apt-get install/remove, apt-show-versions will do is job and all the stdout of apt-show-versions is written in nagios_apt_show_versions.
After that I had to modify my script like this :
#!/bin/bash
#Script qui verifie si les paquets installer sur une machine ne dispose
#pas de versions dans les depots.
STATE_OK=0
STATE_WARNING=1
STATE_CRITICAL=2
STATE=$?
declare -a WHITELISTHOST=(host1:elasticsearch:all host2:elasticsearch:all host2:linux-image-4.9.0-0.bpo.5-amd64:amd64 host3:python-django-flatpages-tinymce:all)
WHITELIST=()
NOT_AVAILABLE=()
HOST=$(hostname)
if [ "$STATE" = 0 ]; then #Verifie la condition apt-show-version = installer
    #Verifie que le fichier n existe pas et le cree
    if [ ! -f "/tmp/nagios_apt_show_versions" ]; then
        touch /tmp/nagios_apt_show_versions
    fi
    packets=$(grep 'No available version in archive' /tmp/nagios_apt_show_versions | cut -d: -f1)
    for white in "${WHITELISTHOST[@]}"; do
        if [ "${HOST}" = "$(echo $white | cut -d: -f1)" ]; then
            WHITELIST+=("$(echo $white | cut -d: -f2)")
        fi
    done
    for packet in $packets; do
        if [ "${WHITELIST[@]}" != "${packet}" ]; then
            NOT_AVAILABLE+=("$packet")
        fi
    done
        #Ok dans Nagios
        exit $STATE_OK
    else
        echo ${NOT_AVAILABLE[*]}
        exit $STATE_WARNING
    fi
else
fi
BTW the Withelist is now working (well kind of but dat's not goal of this thread, I was just asking about hooks)
Ghrew
  • 51
Consider using lsof to check if the file is in use, as recommended on related Serverfault post. You could do something like this:
while [ "x$(lsof /var/lib/apt/lists/lock)" != "x" ] ; do
    # if lsof returns output, that means some apt task is running
    # wait 60 seconds and check again
    sleep 60
done
Another command would be fuser (and IMHO better than lsof). According to documentation:
fuser returns a non-zero return code if none of the specified files is accessed or in case of a fatal error. If at least one access has been found, fuser returns zero.
This means you can rely on exit status in the loop, which makes the syntax nicer:
while fuser /var/lib/apt/lists/lock > /dev/null ; do
    sleep 60
done
Ideally, you probably should use fnctl() type of function to see if file is locked, either via C or Python.
See also:
