My VPS wasn't rebooted for about 3 months. It is hosted on a server with OpenVZ virtualization type and the operating system is Ubuntu 16.04. For some reason, I rebooted the VPS and after that, I couldn't connect to the server through ssh, the message that I received is:
ssh: connect to host srvname.com port 22: Connection refused
So I opened a Serial Console on the VPS and start investigating... I've purged and reinstalled the openssh-server with no success. I spent two hours reading articles, question, and answers about similar issues on Internet.
Finally I managed to understand that the directory /var/run/sshd is not created during the system startup. And once I create it manually I can start the SSH service without any problem, but on the next reboot the issue remains. So my questions are:
What could be the cause of this issue? Why
/var/run/sshdis not created during the system startup?How can I solve the issue in a proper way? I found a temporal solution that is mentioned at the end of this post.
Does the issue could be related to the OpenVZ host of the VPS? Should I ask the hosting provider to solve it?
The output of systemctl status ssh.service, sshd -Ddp 22 and journalctl -xe is:
# systemctl status ssh.service
● ssh.service - OpenBSD Secure Shell server
Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: enabled)
Active: failed (Result: start-limit-hit) since вт 2019-01-15 12:58:08 EET; 22s ago
Process: 407 ExecStartPre=/usr/sbin/sshd -t (code=exited, status=255)
яну 15 12:58:07 srvname systemd[1]: Failed to start OpenBSD Secure Shell server.
яну 15 12:58:07 srvname systemd[1]: ssh.service: Unit entered failed state.
яну 15 12:58:07 srvname systemd[1]: ssh.service: Failed with result 'exit-code'.
яну 15 12:58:08 srvname systemd[1]: ssh.service: Service hold-off time over, scheduling restart.
яну 15 12:58:08 srvname systemd[1]: Stopped OpenBSD Secure Shell server.
яну 15 12:58:08 srvname systemd[1]: ssh.service: Start request repeated too quickly.
яну 15 12:58:08 srvname systemd[1]: Failed to start OpenBSD Secure Shell server.
яну 15 12:58:08 srvname systemd[1]: ssh.service: Unit entered failed state.
яну 15 12:58:08 srvname systemd[1]: ssh.service: Failed with result 'start-limit-hit'.
# $(which sshd) -Ddp 22
debug1: sshd version OpenSSH_7.2, OpenSSL 1.0.2g 1 Mar 2016
debug1: private host key #0: ssh-rsa SHA256:...
debug1: private host key #1: ssh-dss SHA256:...
debug1: private host key #2: ecdsa-sha2-nistp256 SHA256:...
debug1: private host key #3: ssh-ed25519 SHA256:...
Missing privilege separation directory: /var/run/sshd
# journalctl -xe
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit ssh.service has begun starting up.
яну 15 13:21:21 srvname sshd[1688]: Missing privilege separation directory: /var/run/sshd
яну 15 13:21:21 srvname systemd[1]: ssh.service: Control process exited, code=exited status=255
яну 15 13:21:21 srvname systemd[1]: Failed to start OpenBSD Secure Shell server.
-- Subject: Unit ssh.service has failed
-- Unit ssh.service has failed.
-- The result is failed.
яну 15 13:21:21 srvname systemd[1]: ssh.service: Unit entered failed state.
яну 15 13:21:21 srvname systemd[1]: ssh.service: Failed with result 'exit-code'.
яну 15 13:21:22 srvname systemd[1]: ssh.service: Service hold-off time over, scheduling restart.
яну 15 13:21:22 srvname systemd[1]: Stopped OpenBSD Secure Shell server.
-- Subject: Unit ssh.service has finished shutting down
-- Unit ssh.service has finished shutting down.
яну 15 13:21:22 srvname systemd[1]: Starting OpenBSD Secure Shell server...
-- Subject: Unit ssh.service has begun start-up
яну 15 13:21:22 srvname sshd[1691]: Missing privilege separation directory: /var/run/sshd
яну 15 13:21:22 srvname systemd[1]: ssh.service: Control process exited, code=exited status=255
яну 15 13:21:22 srvname systemd[1]: Failed to start OpenBSD Secure Shell server.
яну 15 13:21:22 srvname systemd[1]: ssh.service: Unit entered failed state.
яну 15 13:21:22 srvname systemd[1]: ssh.service: Failed with result 'exit-code'.
яну 15 13:21:22 srvname systemd[1]: ssh.service: Start request repeated too quickly.
яну 15 13:21:22 srvname systemd[1]: ssh.service: Failed with result 'start-limit-hit'.
The content of /usr/lib/tmpfiles.d/sshd.conf and /etc/init/ssh.conf is:
# cat /usr/lib/tmpfiles.d/sshd.conf
d /var/run/sshd 0755 root root
# cat /etc/init/ssh.conf | sed '/^#/ d'
description "OpenSSH server"
start on runlevel [2345]
stop on runlevel [!2345]
respawn
respawn limit 10 5
umask 022
env SSH_SIGSTOP=1
expect stop
console none
pre-start script
test -x /usr/sbin/sshd || { stop; exit 0; }
test -e /etc/ssh/sshd_not_to_be_run && { stop; exit 0; }
mkdir -p -m0755 /var/run/sshd
end script
exec /usr/sbin/sshd -D
Additional information about the system:
# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.5 LTS
Release: 16.04
Codename: xenial
# uname -a
Linux srvname 2.6.32-042stab127.2 #1 SMP Thu Jan 4 16:41:44 MSK 2018 x86_64 x86_64 x86_64 GNU/Linux
# apt show openssh-server | grep 'Version'
Version: 1:7.2p2-4ubuntu2.6
The temporal solution:
I found that /var/run is a symbolic link to /run, I do not know why this is needed, but when I modified the content of the file /usr/lib/tmpfiles.d/sshd.conf from:
to:
d /run/sshd 0755 root root
everything goes well on system startup, the SSH service is started normally and I'm able to log-in via SSH.
