I've recently deleted pulseaudio by mistake, which means that now I'm unable to listen to all audio, which means 90% of all I do on my pc is now off. I tried to reinstall pulseaudio from the command line, but this was the output:
~$ sudo apt install pulseaudio
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
pulseaudio : Depends: libpulse0 (= 1:11.1-1ubuntu7.1) but 1:12.2-5~bionic1 is to be installed
I've tried everything. sudo apt install -f doesn't work, dist-upgrade doesn't work, update, upgrade and autoremove all work properly and don't give back any error, and there are 0 packages to be installed, upgraded or removed. I've tried using apt, apt-get and aptitude. I've tried to fix the broken dependencies with synaptic. Nothing.
If I try to remove or regress libpulse0 it gives me an endless list of packages that are to be removed or will be removed.
I know that I can fix everything with a fresh install, but I'd rather not if at all possible, since last time was a small nightmare, what with UEFI and whatnot.
I'm really at my wits' end. Does anybody have any suggestion?
