Ubuntu 15.10 x86_64 While trying to do an install of Bumblebee, I followed instructions to add the xorg-edgers PPA. A more recent tutorial advised against it. However, by then,it was already too late: several packages were already updated to the xorg-edgers versions.
I thought I might be able to go into Synaptic and force-version these packages back to Canonical. This worked for some packages, but it quickly turned into a dependency nightmare. Some downgrades wanted to uninstall other packages, and some (libegl1-mesa-dev), if elected to be downgraded rather than removed, threatened to uninstall nearly every package currently installed, including everything xorg.
Is there an easy way to roll back everything from a PPA back to Canonical?
**In response to "possible duplicate", removing the PPA wasn't the problem, but rather rolling back the packages without causing a firestorm of dependency problems proved most challenging. However,in the suggested answer, the solution to my question was also given; namely, the ppa-purge solution.
Huaidan
  • 351
Yes, there is an easy way.
Just install ppa-purge
sudo apt-get install ppa-purge
Then you should run it against the PPA you added, in this case:
sudo ppa-purge ppa:xorg-edgers/ppa
It should disable the PPA and rollback any package updated from the PPA back to the ones in the Ubuntu official repository.
http://www.webupd8.org/2012/02/how-to-use-launchpad-ppa-add-remove.html
xangua
  • 7,277
